Cosmos II motherboard temperature
amoshi
Can someone tell me if everything is okay? How on earth is the temperature of the motherboard 97 degrees Celsius?
The laptop doesn't feel hot and the fans aren't loud so I suspect a malfunctioning sensor. What should I do?
My spec is
Cosmos Series: 15.6" Matte Full HD IPS LED Widescreen (1920x1080)
Intel® Core™i5 Dual Core Mobile Processor i5-4210M (2.60GHz) 3MB
8GB KINGSTON SODIMM DDR3 1600MHz (1 x 8GB)
NVIDIA® GeForce® GTX 850M - 2.0GB DDR3 Video RAM - DirectX® 11
1st Hard Disk
de4life
My spec is
1st Hard Disk
I have the same processor, RAM and thermal paste as you and have never approached anywhere close to 97 degrees. It's hard to get this above 50.
If it was truly at 97 degrees the fan should be going crazy trying to expel that heat. Is the fan working properly? If it is then I'd suggest 97 degrees is a false reading, as that's the type of temperature that soon leads to thermal shutdown.
