Hi Chaps and Chapesses,
I've ordered a laptop from the PC Specialist website and it's currently in the 'processing stage'. This will be my first laptop and I'm looking for something that'll be good for 3D modelling software (ie SolidWorks, Autodesk etc), video editing (Hitfilm 2 Ultimate), and general university work. I'm not really a PC gamer at the moment, although I won't have my console with me at Uni so I would like the option of becoming a PC Gamer (!), playing games at reasonable settings (ie Battlefield at medium settings).
I'm slightly worried that my CPU might not be up to the job. Should I upgrade it slightly, if so to a better i5 or i7? Can you guys offer your thoughts on this? My max budget ideally is £700 but ideally I would like to keep it under. Currently the spec below is £677.
Many thanks!
Cosmos Series: 15.6" Matte Full HD LED Widescreen (1920x1080)
Intel® Core™i5 Dual Core Mobile Processor i5-4210M (2.60GHz) 3MB
8GB KINGSTON SODIMM DDR3 1600MHz (1 x 8GB)
NVIDIA® GeForce® GTX 850M - 2.0GB DDR3 Video RAM - DirectX® 11
1st Hard Disk
750GB WD SCORPIO BLUE WD7500BPVX, SATA 6 Gb/s, 8MB CACHE (5400 rpm)
GIGABIT LAN & WIRELESS INTEL® N-7260 (300Mbps, 802.11BGN) + BLUETOOTH
Cosmos Series 6 Cell Lithium Ion Battery (48.84WH)
DVD Recovery Media
Windows 7 Home Premium (64-bit) DVD with paper sleeve
COSMOS SERIES UK KEYBOARD WITH NUMBER PAD
Mouse
Many thanks!
1st Hard Disk
DVD Recovery Media
Mouse
