Hello
So after a day or two playing around with some rgb settings on my pc. i've been unable to sync my corsair h115i platinum rgb to the icue software (it doesn't appear)and only after having another look at the cooler pump, i think there is a cable missing at the side of the pump head which should connect the a usb 2 on the motherboard?
