Corsair 780T
Tysuro
Does the Corsair 780T come in the black version to or is white one the only option @PCS.
James_C
The white one is the only option we have at PCS, if you were looking to get the black one then you can always buy one and send it to us to build into.
iTzCallumUK
I've just noticed something...
Custom Case
Requirements:
  1. The case needs to be no larger than 600mm x 300mm x 630mm (H x W x D).
Corsair 780T
Dimensions:
637mm x 288mm x 602mm (Approx H x W x D)
Doesn't this make the case 37mm too high or does that not matter?
Thanks!
- Callum
Stormshadow
I ordered a black/red Corsair 780T through Amazon, PC Specialist got it the following day. Fabulous case!
Also case fits specs for when it is built and being sent out.
