Core i7 Temp. problems?
thisisevilevil
Hello guys!
Just ordered this beast:
Vortex II: 17.3" Glossy Full HD LED Widescreen (1920x1080)
Intel® Core™i7 Quad Core Mobile Processor i7-2720QM (2.20GHz) 6MB Cache
8GB KINGSTON HYPER-X GENESIS 1600MHz SODIMM DDR3 (2 x 4GB)
2.0GB nVIDIA® GeForce® GTX 580M - DirectX® 11 (17.3" Vortex II)
250GB WD SCORPIO BLACK WD2500BEKT, SATA 3 Gb/s, 16MB CACHE (7200 rpm)
(Will buy a seperate 120GB SSD disk, as the selection PCspecialist had, wasn't very good.)
Intel 5.1 Channel High Definition Audio + SPDIF/MIC/Headphone Jack
GIGABIT LAN & KILLER™ 1102 WIRELESS 802.11N - IDEAL FOR ONLINE GAMING
I know that the 1st generation had temp. problems when it came to gaming. I've seen several laptops from different brands overheat after a mere 2-3 hours of gaming, not to mention that i worked for dell, and had to support Alienware computers
Is this still an issue with the 2nd generation of the i7's? And would it be prudent for me to get myself a cooling pad when i intend to spend several hours of gaming in a row?
