Coolermaster K500 or the H500
morriserick
I like to know your thoughts on the overall performance of the K500 in terms of airflow, temperature, noise and upgradability as compared to the H500. I generally like both designs, although I lean more towards the K500 for its stylish front panel and concealment of the drive bay. There definitely seems to be a lot more enthusiasm and coverage of the H500 with generally positive reviews from Gamers Nexus and not really much from the other.
What do you think would be the wiser choice for a relatively high spec gaming machine?
Thanks.
H500 - simply as there's more information on it so you can be (even) more confident you know what you're getting. Also it's pitched as a higher end case despite the small price difference at PCS. The K500 is a bit more of a budget case.
