I've heard some places that this case has one side of it which is see through, does the case from this website come with that?
No they don't do the see through 310 on here but if you go onto coolermasters website you can order the side-panel with the see through pane in![]()
Unfortunately we don't stock the Window version of this case at present. However, you're welcome to order the case from ebuyer and have it delivered to us using the "Choose Your Own Case" option on our configurator.
Will the Elite 430 be available again, as it has currently been removed as an option?
