Cooler options
BT81
H100i x
H115i RGB Pro
H100i x PCS quiet fans
H115i RGB Pro PCS quiet fans
H100i platinum
H115i platinum
Bascially. Top to bottom. Which is the best to buy? Noise is probably my biggest concern. Just as I amend my order for the millionth time. Of writing the 115i platinum is out of stock.
It’s all going to depend on which case and CPU you’ve got... full specs would be handy 👍
3600x. I know it won't require a lot of cooling, why I omitted it mentioning it :) Just a case of which is the best / quietest, assuming 115 platinum is out of stock :)
The coolermaster 240 will be more than enough on that CPU. If you really want a corsair then the H100i Platinum would be overpowered but a good investment.
BT81
Cool. I'll change to the H100i Plat (assume its quiet?) - and then it's suitable for the when 'if / when' I upgrade the CPU in the future :)
skril
If you realy need only platinium make sense for.future.
But in my opinion stock.one is enough
