Control Center Issue.
GonzoN1.
Hello everybody im currently facing this issue. If anybody experienced or meet this kind of thing any help is appreciated.
So i upgrade a few months ago to w11 from w10 . And yesterday i decided that i want to do a clean install of w11 (started to run slow) . After the install i noticed that CC is not working at all and realise that this issue is with w11 because it happend in the past. I put on w10 but surprisingly i noticed the CC still not working. I did some dig ups and realise that it could be the secure boot on wich can interfere with the instalation. Anyone knows how to proper reset secure boot so i can install CC ? Or is there any OEM fixes wich can help? Thanks
P.S.
The CC worked perfectly before reinstalling windows
P.S.
Is this a pcspecialist system? Can you post your full specs from the order page?
GonzoN1.
Chassis & Display Ionico Series: 17.3" Matte QHD 165Hz sRGB 100% LED Widescreen (2560x1440) Processor (CPU) Intel® Core™ i7 Eight Core Processor 10875H (2.3GHz, 5.1GHz Turbo) Memory (RAM) 64GB Corsair 2666MHz SODIMM DDR4 (2 x 32GB) Graphics Card NVIDIA® GeForce® RTX 3070 - 8.0GB GDDR6 Video RAM - DirectX® 12.1 1st M.2 SSD Drive 2TB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3300MB/W) Memory Card Reader Integrated Micro-SD Memory Card Reader AC Adaptor 1 x 230W AC Adaptor Power Cable 1 x 1 Metre UK Power Cable (Kettle Lead) Battery Ionico Series Integrated 91WH Lithium Ion Battery Thermal Paste STANDARD THERMAL PASTE FOR SUFFICIENT COOLING Sound Card 2 Channel High Definition Audio + MIC/Headphone Jack Bluetooth & Wireless GIGABIT LAN & WIRELESS INTEL® Wi-Fi 6 AX200 (2.4 Gbps) + BT 5.0 USB/Thunderbolt Options 1 x USB 3.2 PORT (Type C) + 3 x USB 3.2 PORTS Keyboard Language IONICO 17 SERIES RGB BACKLIT UK KEYBOARD Operating System Windows 10 Home 64 Bit - inc. Single Licence [KUK-00001
davhun
The Control Centre is probably included with the drivers in your PCS account. Try going to "My Account", Tech Support, Download. Install after downloading.
GonzoN1.
Did that, same thing. Reinstalling after fresh windows with secure boot off...reset secure boot keys. No ideea how did it get corrupted . It should be a fix or something
You'd need an updated control center for windows 11. You may have to refresh the BIOS as well
GonzoN1.
I noticed that everytime i install it or reinstall it manually the certificate seems to be valid until march,,,is like is not refreshing ! Maybe thats the issue...
GonzoN1.
And indeed thats the issue. 🫥🫥. After 6 windows installs,,,,hours on the search ....i found a different CC from a different brand/company wich worked but not with all the memory tunning setting wich i`m interested on....Damn...I message PCSpecialist Guys to update the CC Drivers on the download page.
I wouldn't use another SIs version as they'll be designed for a different BIOS
