Constant Fan - wont turn off ever
hargil
The CPU fan on my vortex 3 never turns off.
I am talking about the left hand fan, behind the F1, F2…. Keys.
This is a new thing, it would normally turn on for a bit then after a while turn off as needed.
The CPU temps have a max value of 75C
The fan keeps running even if I am not using it.
The vents look clear, it sits on a table top with nothing under the laptop.
The exit air is warm not excessively hot.
Any advise?
thanks
