As the title says, I am considering upgrading my custom PCS PC to try to make it quieter during periods of demanding gaming.
I play at 1440p and with the highest settings I can. I have a good system for gaming (see specs below) and I get great performance. However, when playing some of the more demanding games (S.T.A.L.K.E.R 2, Cyberpunk, etc) my system gets very loud, and I would like for it to be quieter if possible.
Currently, I have a DeepCool AG400 Performance CPU cooler, which does a fairly decent job of cooling my Ryzen 7 7800X3D, with idle temperatures sitting around 45c, never surpassing 80c during high intensity gaming. However, I am unsure if this cooler is ideal for my CPU going forward, or if I should upgrade it while I have the budget to do so (I was looking at some options PCS offer - such as Corsair iCue Link Titan 360 - as I will be using PCS's upgrade service).
My case is the Corsair 4000D AIRFLOW Tempered Glass Mid-Tower ATX which seems to have sufficient air flow. I also clean my system regularly, live in a cold climate, and my room is one of the coldest in the house.
I suppose I am just wondering if an upgrade to my existing CPU cooler would reduce noise during gaming (and if it improves cooling, that's a bonus) or if there are further considerations I should make before I make that upgrade. I do not have any strict budget constraints.
Specs:
I truly appreciate any advice on this matter, my system is great, but this is the only 'downside' (and it's not a major issue, truly) I will be able to provide more information if necessary.
Thank you!
Specs:
ASUS® TUF GAMING B650-PLUS WIFI (DDR5, USB 3.2, 6Gb/s)
32GB Corsair VENGEANCE RGB DDR5 6000MHz (2 x 16GB)
20GB AMD RADEON™ RX 7900 XT - HDMI, DP - DX® 12
2nd M.2 SSD Drive
NOT REQUIRED
DeepCool AG400 Performance ARGB CPU Cooler
ONBOARD 2.5Gbe LAN PORT
NOT REQUIRED
Thank you!
