Considering new laptop for heavy use & ocassional gaming
madriss
Hi :)
Although it's still a very capable machine I'm gradually getting frustrated with my current laptop not being quite snappy enough, plus overheating if I do anything CPU intensive. I use it all day every day and often leave it on all night too (that bad? haha) I'm considering upgrading at some point this year but haven't decided when or exactly what spec I want. Just want to make sure when I do get it that it's a good enough investment really plus it's a matter of timing cost-wise particularly considering things like SSD. I've never gone for a custom build and had this many options to consider before or spent this much money!
I'm looking at something like Optimus IV / SkyFire / Vortex III. I did consider downsizing to a 15.6" now that they come in full HD, but 17.3" is probably better for what I do plus gives everything more room so I'm almost sure on that. Question though: Directly comparing with 1920 x 1080 is the difference quite pronounced / things extremely small on a 15.6"? Any other negatives to consider with a 15.6" other than the keyboard?
What it's for:
Day to day I use text editors (occasionally looking at huge files / doing search & replace, or using an IDE), file/folder contents searches, web browsing with usually about 30 or more tabs open at once, Photoshop for editing multiple images & web design, plus some other programs like Skype, emails and Office software or music running, and I watch HD video content. I sometimes run things over LAN and use a WAMP server locally and work with databases.
Also I often convert video files to different formats to publish to the web e.g. MP4 to OGV.
I also often use a second monitor for work, but I assume that doesn't make much difference.
On the game side I'm not fussy about having everything set on highest graphics with high textures & lighting etc (though that's nice!) but would just like to know I can play whatever I feel like and that it will run smoothly if a game comes out I want in a few years from now. Right now apart from Minecraft the only big one I can think of I might get is Elder Scrolls online but like to have my options open.
Main components:
Is the standard graphics you get with these models good enough and future proof? (GTX 660M / 670M?)
Would something like an i5-3210M be good enough for what I do or would I be best off investing a bit more for the long term on more Ghz or even an i7?
Although I did want to try to keep the cost down, considering everything I do I think an SSD would be worth paying more for - I'm currently using a large portion of my 500GB hard drive though so space is an issue. If I manage my files well I could probably get away with a 240GB SSD for primary use, plus an additional hard drive for backups and other storage.
If I do that and the SSD prices plummet again as bigger ones come out or something though I might be a bit miffed! I would like a 480GB really but the difference in price is huge and I'm guessing it's going to stay that way?
I definitely want to go up to 8GB RAM, but leaving it open to future upgrades would be nice. Is 2x4GB much better than 1x8GB or is it better to get the latter and leave an extra slot open? When I looked it was only £3 difference. Would more than 8GB be of any benefit or just wasteful? (I remember thinking 4GB was a lot when I bought my current laptop!)
Extras / Details:
Current laptop has a bit of an overheating issue but I think that's just because it's a cheap build, should I get the better thermal compound or is standard good enough?
A bit tempted by Windows 8 just to feel up to date but I really love Windows 7 and 8 seems a bit of a mess, so I'll probably stick with my 7 Home Premium, maybe re-use my current license key if that's possible?
What is the use of the higher Wireless/LAN options? The standard seems pretty fast and decent to me. Are they for specialist uses? What if I upgrade to a fibre broadband connection?
I guess the only other thing I thought about is a Blu Ray drive, is it easy to upgrade to one in future? I don't think I really need one right now. Maybe it depends on if I have a second hard drive though? Not sure if you can just change the DVD drive out.
What is the use of the higher Wireless/LAN options? 150Mb seems pretty fast to me.
Oops:
Sorry it's a big post! It's an investment for me and I'm fussy! Thanks a lot guys. Other than deciding how long to wait to get the best price (this is more a want than a need right now!), I think it's mainly future-proofing the (possible/probable) SSD & processor combo and graphics that I'm concerned with.
Build:
This is one possible build I just looked at which keeps things at a reasonable price. What I really want would be about £500 more :p
Would this processor be a lot better though for not much more money?:
Intel® Core™i7 Quad Core Mobile Processor i7-3630QM (2.40GHz) 6MB
Code:
SkyFire:17.3" Matte Full HD LED Widescreen (1920x1080)
Intel® Core™i5 Dual Core Mobile Processor i5-3210M (2.50GHz) 3MB
8GB SAMSUNG 1600MHz SODIMM DDR3 MEMORY (2 x 4GB)
NVIDIA® GeForce® GTX 670M - 1.5GB DDR5 Video RAM - DirectX® 11
Memory - Hard Disk
240GB KINGSTON HYPERX 3K SSD, SATA 6 Gb/s (upto 555MB/sR | 510MB/sW)
500GB WD SCORPIO BLACK WD5000BPKT, SATA 3 Gb/s, 16MB CACHE (7200 rpm)
Integrated 4 in 1 Card Reader (SDXC/MMC/MS/XD)
Bluetooth & Wireless
GIGABIT LAN & INTEL WIRELESS 802.11N CARD INC. BLUETOOTH 3.0
2 x USB 3.0 PORTS + 3 x USB 2.0 PORTS AS STANDARD
SkyFire Series 9 Cell Lithium Ion Battery
Power Lead & Adaptor
1 x UK Power Lead & 180W AC Adaptor
INTEGRATED UK KEYBOARD WITH NUMBER PAD
Notebook Mouse
INTEGRATED 720P 30 FPS HD WEBCAM
Insurance
Price: £935.00 including VAT and delivery.
