Configure too complicated
MacNala
I have 2 earlier PCs running Windows 10 from PCSPECIALIST. I need to add a new machine to support a change to Windows 11.
I find the options to configure a new PC too complicated. I do not understand the options I could choose in almost every area of specification.
I think I need to change over to touch screen as well, which brings up the question of which Monitors have video and speakers. How do I specify Wi-Fi
and/or Bluetooth. SSD or NV Me drives. Which GPU the list goes on and on, how do I get help?
My current machines have Intel i7-4930K @ 3.4 GHz, 32GB, Blu-ray DVD writer, multiple HDDs, NVIDIA GTX770 GPU, multiple Routers including 1 from ISP.
steaky360
You might be better off using one of the pre-specified machines or certainly starting from there if starting from a base spec is overwhelming (too much choice etc.)
What are you wanting to do with the PC? There's several questions in the link that @SpyderTracks posted above which will be very helpful to allow someone else to take you through specifying a PC if thats more appropriate.
MacNala
Thanks for the replies. I will look again at the pre-built models and see if I can go from there.
As to what I want it for is difficult as my situation has recently changed a better idea could be from my current usage.
I monitor my solar PV system using Excel, I watch a lot of YouTube videos, I want to resurrect my interest in flight simulators, I play a lot of Go,
Does that give you enough to help me choose which pre-built system to start from?
I do not use any social media platforms.
If you can go through the linked thread and answer the questions?
