Comments on this spec before I order
rontuo
Just specced up a new laptop for business, gaming, watching movies, sound, etc, any comments on the spec below?
Vortex II: 15.6" Matte Full HD LED Widescreen (1920x1080) (£79)
Intel® Core™i7 Quad Core Mobile Processor i7-2760QM (2.40GHz) 6MB
16GB SAMSUNG 1333MHz SODIMM DDR3 MEMORY (4 x 4GB)
2GB AMD® Radeon® HD 6990M - DirectX® 11 (15.6" Vortex II)
500GB SEAGATE MOMENTUS XT HYBRID, SATA 3 Gb/s, 32MB CACHE (7200 rpm)
SONY BD-5730S 6x BLURAY WRITER & CYBERLINK SOFTWARE (£89)
ARCTIC COOLING MX-3 HIGH THERMAL CONDUCTIVITY COMPOUND (£9)
Creative Sound Blaster® X-Fi™ HD - Audiophile-Grade Notebook Sound (£79)
GIGABIT LAN & KILLER™ 1102 WIRELESS 802.11N - IDEAL FOR ONLINE GAMING
Thanks in advance!!
Rakk
The Awesome
You may find that 16GB of RAM is a bit over the top, though this depends on what business stuff you may be doing, the rest of your listed things you'll be doing won't need anywhere near 16GB :)
rontuo
Business wise a lot of development related applications from Visual Studio through to Powerpoint and Project + VPNs, VNC, etc. It probably is over the top but memory is cheap and I'll be running W7Ult 64 bit, so I'd rather have too much than too little.
Problem is you start with a max budget then fill it up, whatever it takes [rollinglaugh] And I haven't gone for the gold plating..........................
