Coming pc.
ekeis
A bit late I guess since the pc is awaiting dispatch, but here are my specs.
Case COOLERMASTER COSMOS 1000 SILVER SILENT CASE
Overclocked CPU Overclocked Intel® Core™i7-2700k Quad Core(3.50GHz @ max 5.00GHz)
OC Settings Show/Hide
Motherboard ASUS® P8Z68-V PRO/GEN3: PCI-E 3.0 READY, SLI, CROSSFIREX
Memory (RAM) 16GB KINGSTON HYPER-X GENESIS DUAL-DDR3 1600MHz, X.M.P (4 x 4GB KIT)
Graphics Card 1.5GB NVIDIA GEFORCE GTX 580 - 2 DVI, HDMI, DP - 3D Vision Ready
2nd Graphics Card 1.5GB NVIDIA GEFORCE GTX 580 - 2 DVI, HDMI, DP - 3D Vision Ready
3rd Graphics Card NONE
Memory - 1st Hard Disk 120GB KINGSTON HYPERX SSD, SATA 6 Gb/s (upto 555MB/sR | 510MB/sW)
2nd Hard Disk 120GB KINGSTON HYPERX SSD, SATA 6 Gb/s (upto 555MB/sR | 510MB/sW)
RAID RAID 0 (STRIPED VOLUME - 2 x same size & model HDD / SSD) (£9)
1st DVD/BLU-RAY Drive 10x LG BLU-RAY RE-WRITER DRIVE, 16x DVD ±R/±RW (£65)
Power Supply CORSAIR 1050W PRO SERIES™ HX1050-80 PLUS® SILVER MODULAR (£162)
Processor Cooling COOLIT ECO II C240 A.L.C (ADVANCED LIQUID COOLER) (£99)
Thermal Paste ARCTIC MX-4 EXTREME THERMAL CONDUCTIVITY COMPOUND (£9)
Network Facilities ONBOARD 10/100/1000 GIGABIT LAN PORT - AS STANDARD ON ALL PCs
Monitor IIYAMA E2773HDS 27" LED WIDESCREEN, HDMI/DVI-D HD1920x1080 (£229)
2nd Monitor IIYAMA E2773HDS 27" LED WIDESCREEN, HDMI/DVI-D HD1920x1080 (£229)
DVI-D & HDMI Monitor Cables 2 x 2 METRE GOLD PLATED V1.4 HDMI CABLE (£15)
Keyboard & Mouse LOGITECH® G19 GAMING KEYBOARD WITH GAMEPANEL™ LCD (£129)
Speakers LOGITECH Z506 5.1 SURROUND SOUND SPEAKERS - 75W RMS (£79)
Webcam Logitech® HD Webcam C910 - 1080p HD Video & 10 Megapixel Photos (£79)
Surge Protection 6 Socket Compact 2M UFO Surge Protector + Auto Power Off Function (£19)
External Hard Drive WD 1TB My Book Essential USB 3.0 External HDD WDBACW0010HBK (£159)
Warranty 3 Year Standard Warranty (1 Month Collect & Return, 1 Year Parts, 3 Year Labour)
Delivery PCS EXTRA-CARE DIAMOND DELIVERY - MON-FRI, PRE-10AM (£15)
Build Time Standard Build - Approximately 10 to 12 working days
Total Order Price £3,366.00
Production Dates
Processed Date 17-11-2011
Pre-Production Date 22-11-2011
Build Date 22-11-2011
Test Date 25-11-2011
QC Date 25-11-2011
Awaiting Dispatch Date 26-11-2011
Warning wall of text!
Review~
I bought a pc from PCS a couple of years ago, I only had 2 problems with the pc as it came. The first thing was, when it went on sleep mode, the pc would mess up, I don't remember what happened, it was a really long time ago, but when I called PCS, I was told it was from windows vista, and I had to take the battery out the motherboard and put it back in. That kept happening untill I disabled sleep/standby mode.
Second thing was blue screen, I was told it was the RAM, i was sent a brand new set of RAM, which didn't solve the problem. At the end I just used 2 sticks of RAM instead of 4, then added another. So the pc worked on 3, but not 4. They kept trying to help, but after about 10-15 calls and chase ups, I was gave up on the trouble, it was too much hassle. Ofcourse If kept going they would have most likely fixed it.
Which is why I came back here and ordered another PC, knowing they would do anything to help. I ordered this PC, with a Mouse and a Headset. I know sometimes companies delay the order because of minor items. So I called and asked if everything was in stock. I was told the mouse and headset were not. So I asked them dispatch the order without the 2. After a day I thought let me return the mouse and headset, and ask for some discount for a 3rd monitor. I asked on the live chat online, the person said it was ok, and I needed to amend the order. I tried to amend the order for what is being returned and what I want to replace with. Of course it doesn't allow me because it asks for the extra payment. After a couple of messages and I was told to amend the headset and mouse. So I did, then I asked if they can add the monitor. I got a phone call later trying to confirm what is going on and what do I need to be done. After a few things, the end result was, I was refunded the money for the headset and mouse, which I didn't ask for. I didn't get the discount I was promised. Very disappointed. After all that, I was messing around the website, and I noticed my HDD dropped in price by £20. At this point, I'm like after all this and spending over 3k on a PC, £20 is nothing, never mind I don't want to go through all the trouble.
Hopefully I'll get the PC on Tuesday and everything is perfect! Fingers crossed.
UndeadJack
Master Poster
:O Amazing dude! By the way, vista literally blue screens my laptop for for no reason. The hex code says it's ram but my ram is fine - vista just hated computers
AshleyUK
One thing with a PC that expensive I would have upgrade the Guranete to Atleast silver so it come with a Year Return to Base instead of the basic 1 month!
But apart from that great spec PC, Bet that will kill anything you throw at it.
Corfate
Vista also liked to blue screen my pc when i played video's in fullscreen mode, or videos on iTunes..
ekeis
Got my PC as expected, have been really busy so I barely used it. I just noticed the CPU speed says 3.5GHz, how do I check the speed of an overclocked CPU?
Rakk
The Awesome
It will only go above the stock clock speed when it's needed, ie. it doesn't stay at overclocked speeds all the time.
So you need to run something CPU intensive and then find out what speed its running at :)
PokerFace
Banned
As AshleyUK says, I would phone PCS and ask to pay £5 to upgrade to the silver warranty/guarantee. That gives you 1 year collect and deliver instead of the 1 month you currently have (unless you've done so already). Hopefully it will not be needed, but for a fiver, you can sleep easy :)
