Cm storm enforcer vs 690 II advanced case
bg92
Expert
I have the cooler master 690 II advanced, and in my opinion this would a better choice. You should also consider corsair 400r. And out of these 3 pick the one you like the look of the most.
All 3 should provide good cooling.
Tehmoe
Personally I would look at some youtube reviews so you can get a good idea of the inside and out of the case. Both will offer similar levels of cooling so all down to personal taste.
rudolph93
this is exactly i did i got saw the cases i wanted and then went on youtube and looked up some reviews, but in the end i went with the storm enforcer because i decided i wanted a window on it and like how it hides the disk drive and memory card reader.
but its your choice at the end of the day if you still cant choose you could always make a list of pro's and con's for each one and see which is better then ;)
