sumustinis
Hello members,
I have fedora runing but no luck with hdmi output. xorg.0.log show the following:
xrandr show the following:
the mouse pointer can go to the left outside of the visible screen area.
Any ideas how to get output on tv?
[167162.998] (II) intel(0): EDID vendor "LGD", prod id 729
[167162.998] (II) intel(0): Printing DDC gathered Modelines:
[167162.998] (II) intel(0): Modeline "1920x1080"x0.0 139.50 1920 1968 2000 2096 1080 1083 1088 1111 -hsync -vsync (66.6 kHz eP)
[167162.998] (II) intel(0): Modeline "1920x1080"x0.0 93.00 1920 1968 2000 2096 1080 1083 1088 1111 -hsync -vsync (44.4 kHz e)
[167163.051] (II) Quirked EDID physical size to 0x0 cm
[167163.087] (II) intel(0): Allocated new frame buffer 3840x1080 stride 15360, tiled
Screen 0: minimum 320 x 200, current 3840 x 1080, maximum 8192 x 8192
LVDS1 connected 1920x1080+1920+0 (normal left inverted right x axis y axis) 344mm x 194mm
1920x1080 59.9*+ 39.9
1400x1050 60.0
1280x1024 60.0
1280x960 60.0
1024x768 60.0
800x600 60.3 56.2
640x480 59.9
VGA1 disconnected (normal left inverted right x axis y axis)
HDMI1 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 160mm x 90mm
1920x1080 60.0*+ 50.0 30.0 25.0 24.0
1920x1080i 25.0 30.0
1600x1200 60.0
1680x1050 59.9
1280x1024 75.0 60.0
1440x900 75.0 59.9
1280x960 60.0
1360x768 60.0
1280x800 59.9
1152x864 75.0
1280x720 50.0 60.0
1024x768 75.1 70.1 60.0
832x624 74.6
800x600 72.2 75.0 60.3
720x576 50.0
720x480 59.9
640x480 72.8 75.0 66.7 60.0
720x400 70.1
DP1 disconnected (normal left inverted right x axis y axis)
