Clevo fan control alternatives
Álvaro
Does anyone use a fan control tool aside of Hotkey with clevo laptops? I've found it quite limited, especially on the fact that the custom setting does not allow to set a fan curve and caps at 80%; I'd like to be able to set a fan curve which caps at 100% if the temps reach 70ºC or higher. Is not really pressing as I can just FN+1 it, but I would like to automate it.
Álvaro
I tried it, but it doesn't allow me to. I managed to call PCS and they told me that, at least in my model, Clevo locks the fans via the BIOS, so I'm bound to FN+1 them. Fans are defo cheaper than my graphics card or my CPU, and probably easier to swap.
Swapping the fans wouldn't enable control if they're locked out in the bios.
