Clevo Control Center
fabcas
Hello all,
Recently I'm experiencing some problem with the Control Center installed on my Laptop, i.e. it doesn't save the settings during the session, (It's a defiance series based on the PA71 chassis, bought in October). Checking the drivers on Clevo sites, it gives as only choice the version 1.0.32 as possible CC driver, but would it be possible to use the latest version available (1.0.65 or something) from CLevo, even if not declared as formally compatible? Would it work?
Thanks,
MBR
Hello all,
Thanks,
MBR
Can you reply with your clevo model number on the underside of your laptop?
I believe it's chassis dependant.
fabcas
Not yet, thank you very much :) I supposed it was the latest since the Laptop arrived in October.
I'll try to install it. Do you suggest to do a clean installation (uninstalling the old one and installing the latest?)
Yeah, I'd try it like that just to be sure.
The Clevo site is a little misleading tends to list oldest to newest.
I do believe the installations are chassis dependant though so you have to be careful.
fabcas
Thanks again for your help,clean installation and upgrade didn't solve the issue about unsaved setting but at least not all is reset to zero,let's live with it..mbr
