waljoricar
Evening all,
I bought my PC almost 2 months ago and am loving it. I'm just over the moon with everything, including my free copy of Starfield.
On that note, I've noticed that, on two occasions now within the last week, my PC has become very hot when running Starfield. On both occasions it sounded like it was going to take off and I'd describe it as "hot to the touch".
This hasn't happened before and I've been playing Starfield since I bought it. I was worried that it could be an issue with dust build up, but I've taken my PC out of its cupboard and removed the dust covers only to find barely any dust - even after almost two months. Nevertheless, I gave it a good spray with some canned air just in case.
I have a [CORSAIR 4000D AIRFLOW TEMPERED GLASS GAMING CASE] and a CORSAIR H100i ELITE RGB High Performance CPU Cooler fan.
I've attached an image of where I store my PC.
My questions are:
1. Is the storage space for my PC too small? Could that be causing any temperature regulation issues? It's a bit of tight squeeze, but I wouldn't have thought it would be that much of an issue (I typically have that open cupboard door closed).
2. Does anyone else have this type of PC case? If so any case specific tips regarding how often it needs cleaning/dusting?
3. Is there anything additional I can do to keep my PCs temperature down that isn't going to cost a lot?
4. Should I even be concerned? I was really surprised to hear/feel my PC get so loud/hot, but does that just happen sometimes? Should I be worried about stuff like that after only two months?
5. Does anyone have any general tips about cleaning your PC? Like, how regularly, what to use, etc?
As always, thanks so much to everyone who reads and (hopefully) responds. Hope you're having a good start to your week!
My questions are:
