Clean installed Win11 - now BSODs appearing :(
Bhuna50
OK calling out to @ubuysa or any other knowledgeable people please :D - so I did a completely clean install of Windows 11 having decided that as Win10 updated it without my approval that I quite liked it. I got the odd (every couple of days) BSOD but it didnt bother me but I decided that my filing, drives, games etc needed cleaning up - so backed up C, D and E (as had disk 0 split into 2 and disk 1 as storage at the time), and partitioned back to just 2 disks only - no splitting the 1TB to a smaller windows only drive with larger everything else drive....
Well, all went really smoothly, or so I thought, but now I'm suffering from daily, occasionally repetitive BSODs, I have looked into what I could and came across this:
but I'd rather not revert back to Win10 like someone has said works.
I did download the AMD chipset for laptops - from here https://www.amd.com/en/support and tried applying and basically believe I was already up to date anyway with the chipset (a suggesting in the above thread).
Win 11 updates are completely up to date along with all optionals.
I have run sfc / scannow and it did find and repair some files - but again BSOD still here.
So here are the files:
that can be found at the following link - any further help or advice appreciated.
and finally, if its needed, spec:
Optimus Series: 17.3" Matte Full HD 144Hz 72% NTSC LED Widescreen (1920x1080)
Intel® Core™ i7 Eight Core Processor 10875H (2.3GHz, 5.1GHz Turbo)
64GB Corsair 2666MHz SODIMM DDR4 (2 x 32GB)
NVIDIA® GeForce® RTX 2060 - 6.0GB GDDR6 Video RAM - DirectX® 12.1
1TB INTEL® 665p M.2 NVMe PCIe SSD (up to 2000MB/sR | 1925MB/sW)
AC Adaptor
2 x 180W AC Adaptor
2 x 1 Metre Cloverleaf UK Power Cable
Optimus Series Integrated 46WH Lithium Ion Battery
OPTIMUS SERIES RGB BACKLIT UK KEYBOARD
INTEGRATED 1MP HD WEBCAM
Dead Pixel Guarantee
Welcome Book
Thanks in advance.
Andy.
Bhuna50
Have you got the W11 version of control center installed
ooh theres a thought - will get in touch with PCS to get that on my download section.
Message sent to support - will wait to see what they say - thanks Martin - for some reason, totally forgot about Control Centre :D LOL
Have even asked for updated chipset drivers etc if anything exists - will see what they say.
Tron1982
did you try to find it on the clevo website ?
There are a lot of BSOD in your System log, but you only uploaded one mindump. Can you upload all the relevant mindumps please?
Bhuna50
I only had one mini dump (as for some reason it wasnt turned on) - but have had some more BSODs since, so will upload those shortly.
Fingers crossed here too! I've not been able to do a deep dive into your dumps - TBH I don't want to be sneezing all over my keyboard! 🤮
Thise stop codes are almost always related to third party drivers, so installing the proper GC may well be the solution. Let us know. 🙂
Bhuna50
OK - it is certainly better, but I am still getting the odd BSOD, but its something about Hypervisor_Error and goes through the %ages of reboot, but then freezes that I have to then manually press the off button, and back on again.
I havent been able to grab any dumps from this yet but will put a fresh set up during the week if something happens again and let you know - dont worry about looking at anything yet thanks - as quite busy over next few days anyway.
That BSOD is also generally third party drivers related. I'm starting to think you may have a flaky graphics card....
