Check this out, is it good or does it need work?
Paisano
CORSAIR 175R RGB MID TOWER GAMING CASE
NOT REQUIRED
Firefox™
JUNI0R
NOT REQUIRED
Firefox™
Hi there! It looks like a pretty good start although some things could be adjusted. Before we advise on the spec we'll need to know a little more info. 1) What's your budget? 2) What monitor(s) do you have? (either make and model or resolution and refresh rate) 3) What do you plan to use the computer for? And 4) would you be able to provide us with a configurable link? It'll make it a lot for us to recommend changes! (How to do this can be found here)
ColEyt
Firstly the monitor you are using at present is limited to 1920 x 1080 resolution with a refresh rate of 60hz. Whilst that was the standard to aim for about 5 years ago, a 2560 x 1440 monitor with 144hz refresh rate is the de facto choice these days. Furthermore the graphics card you have selected, Nvidea 3070 is a card targeted at displaying 1440p resolution, so if you were to use that with your present monitor, you wouldn't be getting the full benefit of your graphics card.
A 1440p monitor will cost around £350 as a ballpark figure, so would purchasing a new monitor impact upon your pc budget of £2k.
If you are prepared to have a separate budget for the monitor (keeping your pc budget at £2k) when do you realistically think you would be in a position to buy a new monitor.
There are a couple of amendments that are worth making to your present build above, but ideally it would be great if you could clarify the issue on budget before we start to make any recommendations on how to improve your build.
Ok here's a 1440p system at £2000, if you have a budget of about £300 for a monitor a n Odyssey G5 would go with it nicely
16GB Corsair VENGEANCE RGB PRO DDR4 3600MHz (2 x 8GB)
12GB AMD RADEON™ RX 6700 XT - HDMI, DP - DX® 12
Corsair H100i ELITE CAPELLIX RGB Hydro Series High Performance CPU Cooler
NO RECOVERY MEDIA REQUIRED
Price: £2,006.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/swj9HbG5mN/
JUNI0R
Lovely build from Martin here, although I'd be tempted to spend the extra for the RMx850W unit. It's also worth noting with this Case, the RGB RAM will interfere with top mounting the AIO which isn't the end of the world, it's just not quite as nice asthetically. Plus adding an RGB strip will do a lot more for lighting than RGB RAM would.
The RGB RAM was an accident 😂
Yes agree about the 850, even though it's a little bit more than the ££3 difference it used to be
Paisano
Hey guys thanks for the responses and the input given, i have decided to go with this build suggested by JUNI0R, since it will be great for streaming among everything else that I needed
NOT REQUIRED
Firefox™
Price: £2,094.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/GP!GKagKZk/
JUNI0R
NOT REQUIRED
Firefox™
For Context: It simply didn't allow me to post earlier so I DM'ed the spec to OP not wanting to lose the wall of text I generally write with these specs. We had a brief conversation about him streaming (he planned to stream) and his budget (had a budget of 2K for PC alone) and we're able to come up with this. Feel free to make any recommendations and I hope I haven't broken a super taboo unspoken rule!
