Hi
At some stage my aging 3 year old PCS PC will need to be replaced and I have a budget of approximately £650-£700.
I mainly use the PC for internet and mid-level games so it doesn't have to be a fantastic spec but obviously I want the best spec for my money. I've made the below spec:
AMD BULLDOZER QUAD CORE FX-4100 (3.60GHz/6MB CACHE/AM3)
ASUS® M5A97: AM3+ PLATFORM, DUAL DDR3, SATA 6.0GB/s, USB 3.0
1GB NVIDIA GEFORCE GTX 560 - DVI,HDMI,VGA - 3D Vision Ready
500GB SEAGATE Barracuda SATA-III 6Gb/s HDD, 32MB Cache (7200rpm)
SUPER QUIET 22dBA TRIPLE COPPER HEATPIPE AMD CPU COOLER (£19)
Price: £659.00 including VAT and delivery.
Configure Here: http://www.pcspecialist.co.uk/computers/amd-bulldozer-top-spec-pc/
The processor seems to be the best I can get for my price range as the Intel ones are a bit pricey.
I know most applications only use 4GB RAM but the difference in price between 4GB ad 8GB isn't great so I thought it would be worth it. Is there any benefit in getting the 1600mhz as again not a huge difference in price?
I need the case to be at or less than 200mm wide so have gone for the basic one as this is similar to the one I have already and has been fine for cooling. The better cases were either too wide or expensive.
I've never had any issues with the basic PSU's and don't seem to really be able to afford the more advanced ones.
The main question I guess I have is with the 1 GB GTX 560, would this card be better than the 1 GB HD6870? There is hardly any difference in price and before I have always had Nvidia so would prefer to keep with them unless the Radeon card would give me better value?
