check spec :o)
Hi!
I've already placed my order lol and now I'm having worries so I'd appreciate some thoughts - I was recommended the following set up by friends I just tweaked some stuff (case/rgb ram/monitor)
Monitor: i don't have one yet so I just picked
Uses: simple gaming. i have a mac right now and i play minecraft/stardew, with my pc i am hoping to play hades/val/dbd which don't seem super intensive
budget: 1.1-1.2k w/o vat so 1.3k~ with
Things I'm unsure about:
PSU - there was a warning however I was recommended to stick with 550w
Monitor - picked it without really thinking much but I'm happy with 75Hz/5ms
CPU - getting mixed responses but I stuck with what I was told by my friends pc (she had hers from PCS too and is happy with it - we have similar use!) https://www.pcspecialist.co.uk/gaming-pc/
Reconfig link: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/6tmP5S9x!X/
GIGABYTE B550 AORUS ELITE AX V2: DDR4, USB 3.2, Wi-Fi - ARGB Ready
6GB NVIDIA GEFORCE RTX 2060 - HDMI, DP - VR Ready!
256GB PCS PCIe M.2 SSD (2000 MB/R, 1100 MB/W)
1TB CORSAIR MP400 NVMe PCIe M.2 SSD (up to 3480 MB/R, 1880 MB/W)
CORSAIR 550W CV SERIES™ CV-550 POWER SUPPLY
STANDARD AMD CPU COOLER
BullGuard™ Internet Security - 3 User, 1 Year NO ANTI-VIRUS SOFTWARE
Monitor
ASUS VP229HE 21.5"
Monitor Cables
1 x 2 METRE HDMI (M) to DVI (M) 1 x 2 METRE GOLD PLATED V1.4 HDMI CABLE
Welcome Book
Logo Branding
PCSpecialist Logo
Price: £1337.00 including VAT and Delivery
steaky360
Can you include the configurable link?
I would recommend removing bullguard as its simply not required on a modern PC - windows defender is perfectly adequate.
You probably don't need the monitor cable (unless you've been told the monitor doesn't come with a HDMI cable), if it doesn't I think you will want to change to a HDMI to HDMI cable as neither the 2060 nor the VP229HE have a DVI port (I don't think).
I'd consider adding silver warranty which covers you for return fee's for a year incase of any RMA... but that's up to you (its only £5 though).
I've included the link in the main post now !
I was unsure about the monitor cable too, but from your advice I'll change it to HDMI-HDMI as I don't think it'll be included
and Thanks! I'll implement your other suggestions too : ) (Removing bullguard + Silver warranty)
ThoRob
For £24 more I believe you will get a much better experience with the build below I have added my reasoning next to each item.
Alternatively go for the 2nd option below and buy a GPU later when hopefully prices continue to decrease. (this will still run Minecraft and other light gaming)
FRACTAL FOCUS G BLACK GAMING CASE (Window) (Special Offer) (good case and saves £10)
Intel® Core™ i5 Six Core Processor i5-12400F (2.5GHz) 18MB Cache (better and better value for money)
ASUS® PRIME B660-PLUS D4 (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
250GB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 2300MB/W) (you want a fast boot drive for windows)
1TB PCS PCIe M.2 SSD (2200 MB/R, 1500 MB/W) (you are better saving money on your main drive as it will make very little difference for gaming)
CORSAIR 750W TXm SERIES™ SEMI-MODULAR 80 PLUS® GOLD, ULTRA QUIET (needed if you ever want to upgrade, also quieter and better quality.)
AKASA AK-CC6606BP01 CPU COOLER (I have no experience of this cooler but you wont need masses of cooling so should be ok)
WIRELESS INTEL® Wi-Fi 6 AX200 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD + BT 5.0 (modern WIFI card)
Microsoft® Edge
Monitor
ASUS VP229HE 21.5"
Price: £1,361.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-z690-pc/!X5tbchX00/
AMD Ryzen 5 5600G Six Core CPU with Radeon™ Graphics (3.9GHz-4.4GHz/19MB CACHE/AM4) (better integrated graphics than intel)
ASUS® PRIME B550-PLUS (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
Firefox™
Monitor
ASUS VP229HE 21.5"
Price: £984.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/5VZzhdyxu4/
