Check PC Build
Mozu
Its been quite a while since I've upgraded my PC (6 years), still rocking my RTX 2080. I have been saving up for my dream PC.
I am pretty out of the loop on what parts are best, so the build below is the best i could come up with. I have ordered my own case to send in which is Cubeor's Kanto mATX V1.3. Looking to order a RTX 5090 or RTX 5080 to complete this build. I am unsure about the best CPU cooler & fans.
Will all these parts will be compatible/fit into the case? Is it best if I order my own 5080/5090 to compelte this? Will PCS have them in stock?
Really appreciate any feedback and amendments, this system is purely for 4k gaming at high frames. Not looking to upgrade as long as possible.
Send In Your Own Case
Promotional Item
ASUS® PRIME A620M-K (mATX, AM5, DDR5, PCIe 4.0)
64GB Corsair VENGEANCE DDR5 6000MHz (2 x 32GB) KIT
4TB CORSAIR CORE XT MP600 NVMe PCIe M.2 SSD (up to 5000 MB/R, 4400 MB/W)
CORSAIR 1200W RMx SHIFT SERIES™ MODULAR 80 PLUS GOLD, ULTRA QUIET
PCS FrostFlow 200 Series High Performance CPU Cooler
5 x 120mm Thermaltake TOUGHFAN 12 Case Fans
ONBOARD 2.5Gbe LAN PORT
WIRELESS INTEL® Wi-Fi 6E AX210 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD + BT 5.0
Firefox™
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/qt8EQvzZJ0/
