Charger replacement for Recoil IV
Vadim
Due to a theft I am chargerless. Unfortunately PCS has run out of spare parts for it's Recoil chargers. As such i was looking for alternative/charger which work.
I have been thinking of either using an universal charger, but which might be quite weak (120W compared to the normal 230w). Or a MN expensive and potential not working Tongfang 230w
Those are the one I consider. What do people think?
I would ask PCS for advice.
I would also ask them to get a replacement sent by TongFang as they're a partner. I can't believe they've run out of stocks already. But either way, they can get some direct.
If they really can't though, they need to advise you of a suitable replacement model.
