Changing GPU
Mxshki
I use a Tornado R3 Gaming computer I bought about 3 years ago and it uses a GTX 1650, is it possible to change it to a better GTX or RTX GPU considering 1650 is quite outdated now due to games having higher graphics etc, or does the computer have a certain type of GPUs it supports?
It will depend on whether the PSU and case will accommodate your choice.
Can you post your full spec from your account (plus any changes you’ve made).
Mxshki
I bought the PC from Currys and not from PC Specialist, is there any other way to find the full specs?
