steveuk87
Super Star
Hey guys,
tried burning a CD earlier and it error'd, the log says this:
Any ideas on how to fix this? i'm all updated to latest drivers, and as far as i can see no plugs are loose...
Regards
Steve
9004-027E-UM18-71C6-57TK-P034-****-****
Windows 7 6.1
AMD64
Wow64Process
Nero Version: 11.0.23.100
Internal Version: 11,0,23,100
Recorder: <Optiarc DVD RW AD-7260S> Version: 1.00 - HA 1 TA 0 - 11.0.23.100
Adapter driver: <Serial ATA> HA 1
Drive buffer : 2048kB
Bus Type : via Inquiry data
CD-ROM: <DEF 745Y78PARK >Version: 3.5Z - HA 1 TA 1 - 11.0.23.100
Adapter driver: <IDE> HA 1
=== Scsi-Device-Map ===
: AMD 2+0 Stripe/RAID01.10 ahcix64s Port 4 ID 0 DMA: Off
: AMD RAID Console 1.00 ahcix64s Port 4 ID 10 DMA: Off
: Optiarc DVD RW AD-7260S 1.00 ahcix64s Port 4 ID 2 DMA: Off
CdRomPeripheral : DEF 745Y78PARK 3.5Z ah4a9m65 Port 5 ID 0 DMA: Off
=== CDRom-Device-Map ===
DEF 745Y78PARK E: CdRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 4095MB (4194303kB)
Free physical memory: 4095MB (4194303kB)
Memory in use : 34 %
Uncached PFiles: 0x0
Global Bus Type: default (0)
Check supported media : Disabled (0)
6.5.2013
Audio CD
12:10:08 #1 Text 0 File SCSIPTICommands.cpp, Line 464
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Regards
Steve
