Case?
lastho
This is the spec (for now) I'm looking to see what AMD comes out with tomorrow
I'm not at all sure about the case though? I do like my PC to be quiet, so can I run the 3 front fans at very low speed and will they work with the M/B?
Extra to go in the case/setup:
I will need to put in an extra USB-3 card as I have so many damn many devices to add and they take extra resources part from just the ports).
I will be adding a 2TB sata SSD from my old/current pc.
FYI
The RGB is sort of a nice to have and I figured the extra fans would help with the airflow. if there is a better pure black case that's ok with me.
I am also considering the Corsair 275R airflow (and the 4000D airflow, but that case is not on the list of options)
I have a max height restriction of 480mm hight of the case due to a crossbar under my desk.
Question is the TD500 the best case for the job or should I go with something else (please specify and why)?
I'm mainly looking for a quiet system (and low-speed constant airflow may help with that) & something that is easy to work with should I need to add extra storage etc.
COOLERMASTER MASTERBOX TD500 MESH RGB GAMING CASE
AMD Ryzen 9 3900XT 12 Core CPU (4.7GHz/70MB CACHE/AM4)
64GB Corsair VENGEANCE DDR4 3200MHz (4 x 16GB)
10GB NVIDIA GEFORCE RTX 3080
2TB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3300MB/W)
Corsair H115i PRO Cooler w/ PCS Ultra Quiet Fans
NO RECOVERY MEDIA REQUIRED
Price: £2,914.00 including VAT and Delivery
