To be honest I quite like the look of the InWin Dragon Rider case!
But I just want the case best for cooling, as well as looks
The Inwin Dragon or the 690 II coolermaster are both good cases, either will provide good air flow. Since the primary use is video editing I'd try to get a good cpu cooler.
I'm getting the TITAN FENRIR EVO EXTREME HEATPIPE CPU COOLER (£39), what do you recon?
I think for the Inwin Dragon rider the side panel fan may have to be taken out to fit the titan fenrir,
It says on the website that it's all compatible, If so the side fan might be moved to another place in the case?
Looks good. I am not sure if you would benefit from the 1600mhz, you could perhaps consider the 1333mhz samsung. I found this article quite interesting regarding different memory bandwidth:
http://www.anandtech.com/show/4503/sandy-bridge-memory-scaling-choosing-the-best-ddr3/8
As a corollary, we've seen that some applications do react differently to higher memory speeds than others. The compression and video encoding tests benefited the most from the increased memory bandwidth while the overall synthetic benchmark and 3D rendering test did not.
Read more at http://www.anandtech.com/show/4503/...-choosing-the-best-ddr3/8#05pHpHOXWOMjVORM.99
