Case/GPU/USB problems! Could use a hand!
AndHob
Hi all. looking to amend the usb options on my configuration to the 2 port (type a & c) pci e card option (To give me a usb c in for my atem mini pro). When I do - the configurator throws out that my Gpu is now too big for the case. Then if I switch to one case up on the options it objects to the cooler.
Can someone advise on how best to proceed? Cheers guys
CaseFRACTAL MESHIFY C BLACK GAMING CASE (Window)
MotherboardASUS® CROSSHAIR VIII HERO (DDR4, PCIe 4.0, CrossFireX/SLI) - RGB Ready!
Memory (RAM)32GB Corsair VENGEANCE DDR4 3600MHz (4 x 8GB)
Graphics Card10GB NVIDIA GEFORCE RTX 3080 - HDMI, DP (Delivery before Xmas not guaranteed)
1st Storage Drive3TB SATA-III 3.5" HDD, 6GB/s, 7200RPM, 64MB CACHE
2nd Storage Drive3TB SATA-III 3.5" HDD, 6GB/s, 7200RPM, 64MB CACHE
1st M.2 SSD Drive500GB SEAGATE FIRECUDA 520 GEN 4 PCIe NVMe (up to 5000MB/R, 2500MB/W)
RAIDRAID 1 (MIRRORED VOLUME - 2 x same size & model HDD / SSD)
DVD/BLU-RAY DriveNOT REQUIRED
Processor CoolingCorsair H115i PRO Cooler w/ PCS Ultra Quiet Fans
Change to: Corsair H115i RGB PRO XT Hydro Series High Performance CPU Cooler
Change to: STANDARD THERMAL PASTE FOR SUFFICIENT COOLING
Extra Case Fans1x 120mm Thermaltake TOUGHFAN 12 Case Fan
Wireless Network CardWIRELESS 802.11N 300Mbps/2.4GHz PCI-E CARD
Change to: WIRELESS INTEL® Wi-Fi 6 AX200 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD + BT 5.0
Change to: NO ANTI-VIRUS SOFTWARE
BrowserGoogle Chrome™
Mouse PadNONE
Change to: PCS Mouse Mat - XXL
Streaming AccessoriesElgato Stream Deck XL
Change to: 3 Year Silver Warranty (1 Year Collect & Return, 1 Year Parts, 3 Year Labour)
AndHob
I’m 77 days in on this order & hoping this might be my last chance to make changes (well... a month left I guess....). I’d like to change the usb options on my configuration to the 2 port (type a & c) pci e card option (To give me a usb c in for my atem mini pro). But when I do - the configurator throws out that my Gpu is now too big for the case. Then if I switch to one case up on the options it objects to the cooler.
Can someone advise on how best to proceed? Which case/cooler in the same price range should I be going for that will fit with the added pcie board?
Cheers guys
sck451
Just to check -- do you realise the motherboard already includes a USB Type C port? (Also, I'm pretty sure you can use a type A to type C cable for the Atem.)
AndHob
I didn’t! Thank you!
My thinking was the upgrade to the usc c board was pretty much cheaper than buying a type A to C adaptor
