Case Fans - Replacement
BT81
So. As the other thread, I mentioned about case fans, turned in an reinstall windows thread (and thankfully resolved, thank you mods!)
I thought I would tackle other 'issues' one at a time.
1. Case Fans.
I have the below build and using a little DB app on my phone, most of the noise from the build is coming from the two case fans, rather than the cooler fans. Spydertracks kindly recommended downloading and using AI Suite. However - The difference between 'silent mode' and the standard mode was zero change in fan speed.
I am coming from using 'modern' zero noise laptops (unless gaming, when the fans kick in, and LOUD). Which when I am studying, it perfect. So whilst the PC is probably quiet for most, the case fans are too loud when studying (the GPU fans don't kick in until 50, which isn't a problem when reading text :) )
So what are my options? Can I simply config them to remain off unless the case gets to x degrees? Or, do I simply buy some new case fans (not ideal, but if it's going to annoy me, and I can't turn them off during study time, then I don't mind :) ....)
Regards
BT81
Case NZXT H511 MID-TOWER GAMING CASE (WHITE)
CPU AMD Ryzen 5 3600 Six Core CPU (3.6GHz-4.2GHz/36MB CACHE/AM4)
Motherboard ASUS® TUF X570-PLUS GAMING (USB 3.2 Gen 2, PCIe 4.0, CrossFireX) - ARGB Ready!
Memory (RAM) 16GB Corsair VENGEANCE DDR4 3200MHz (2 x 8GB)
Graphics Card 10GB NVIDIA GEFORCE RTX 3080 - HDMI, DP
1st M.2 SSD Drive 500GB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3200MB/W)
Power Supply CORSAIR 750W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Processor Cooling Corsair H115i RGB PLATINUM Hydro Series High Performance CPU Cooler
Wireless Network Card WIRELESS INTEL® Wi-Fi 6 AX200 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD + BT 5.0
