My PSU is a CORSAIR 750W ENTHUSIAST SERIES™ MODULAR TXM-750 V2-80.
I now have 4 drives in my PC and the consequent connections result in this:
which makes it impossible to get the side panel back on properly.
I can't see any other way of using all 4 power connections. Is there a different way? When I had 3 I was able to make the cable flat enough that the side cable could go back on.
I have a CORSAIR CARBIDE SERIES™ 300R COMPACT case (which you see here straddling the bottom rungs of a Black & Decker workmate).
The SSD in the top drive tray was installed by PC Specialist. The bottom 3 trays go in and out with no problem. The top drive tray won't move at all, it is as if it were built into the case, I can't see what is stopping it from moving.
Any ideas?
Any ideas?
