cant turn of back light or change configuration on Vortex IV please help
Mpatel89
Hey guys I have a vortex IV, i noticed that I couldn't open the backlight configuration menu and I can't turn the back light off. Its permanently stuck on blue. I tried to do system restore thinking it could have been a recent windows update. Instead it went back a week, erased all the system restore points and stopped windows update from opening at all and has not fixed the problem. I have tried uninstalling the hotkeys 7.0030 driver (can't open) after doing a clean boot (windows update now works) but still no luck with opening up the lighting configuration. Also when I changed volume or brightness I use to get a small animation in the top left of screen which has now stopped also. I am on windows 7 64bit.
Any suggestions would be greatly appreciated
I have just pasted the specs incase that makes a difference
Chassis & Display Vortex Series: 15.6" Matte Full HD LED Widescreen (1920x1080)
Processor (CPU) Intel® Core™i7 Quad Core Mobile Processor i7-4700MQ (2.40GHz) 6MB
Memory (RAM) 16GB KINGSTON HYPER-X GENESIS 1600MHz SODIMM DDR3 (2 x 8GB)
Graphics Card NVIDIA® GeForce® GTX 770M - 3.0GB DDR5 Video RAM - DirectX® 11
2nd Graphics Card NONE
Memory - Hard Disk 120GB KINGSTON HYPERX 3K SSD, SATA 6 Gb/s (upto 555MB/sR | 510MB/sW)
2nd Hard Disk 750GB WD SCORPIO BLACK WD7500BPKX, SATA 6 Gb/s, 16MB CACHE (7200 rpm)
mSATA SSD Drive NONE
DVD/BLU-RAY Drive 2nd/3rd HDD HARD DRIVE OPTICAL BAY CADDY
Memory Card Reader Internal 9 in 1 Card Reader (MMC/RSMMC/SD: Mini, XC & HC/MS: Pro & Duo)
Bluetooth & Wireless GIGABIT LAN & KILLER™ 1202 WIRELESS GAMING 802.11N + BLUETOOTH 4.0
USB Options 3 x USB 3.0 PORTS + 1 x USB 2.0 PORT AS STANDARD
Firewire 1 X 1394a FIREWIRE PORT
Battery Vortex Series 8 Cell Lithium Ion Battery (5,200 mAh/76.96WH)
Power Lead & Adaptor 1 x UK Power Lead & 180W AC Adaptor
Operating System Genuine Windows 7 Home Premium 64 Bit w/SP1 - inc DVD & Licence
DVD Recovery Media Windows 7 Home Premium (64-bit) DVD with paper sleeve
Office Software NO OFFICE SOFTWARE
Anti-Virus BULLGUARD INTERNET SECURITY - FREE 90 DAY TRIAL
Laptop Cooling Stands NONE
Carry Case NONE
Stand-Alone Monitor NONE
Keyboard Language INTEGRATED BACKLIT UK KEYBOARD WITH NUMBER PAD
Additional Keyboard NONE
Mpatel89
Hey I uninstalled the hotkeys driver restarted and the backlight still stays on. I reinstalled the driver from the pcspecialist website and I still can't open the program. In the icon tray the hotkey icon has a red circle with a strike through it as though its not there.
