cant get picture for pc
greybing
hello,got my pc today but have had a few problems ,firstly i have the palit geforce 460 and i was hoping to connect my lcd tv to my pc via a hdmi cable,i have no other method of connecting my pc to the tv, i also have no monitor ,just this tv.for whatever reason i can not get a picture.the tv has a vga connection also but i have no cable ,could anyone helps
Gorman
Hi greybing, if the PC is booting and you hear the post beep etc you will just need to set the TV as a display in the drivers, easier said than done with no monitor!, best to give us a call.
greybing
when i switch on the pc there is a very quiet beep,this is normal
i cant switch the pc off at the power button though
greybing
just noticed i have a vga connection on my tv ,if i connected the pc via this would i get a picture instantly.
Gorman
unfortunately i have no phone,yes you read right,no phone...
Ok, Skype details please!
Yes thats the post beep, he is our friend and it means the machine is booting correctly.
It should, if you have the right cable.
greybing
my beep is little feminine,i think its a girl.......just got a 'high quality vga monitor lead' ,still cant get an image......also im currently using a ps3 online,not skype compatible,...ive got a pc savy mate hes got a couple of monitors ,hopefully i can persuade him to bring one to my house and change display to tv that way...thaks or your help mate......also my titan fenrir is just a little loose ,is that good,ok...its not really loose,just a tad-
Sleinous
Sure its not the side fan? That just clips on with metal clips, god only knows how many times ive taken it off to change my RAM thats hiden under it ;) Just make sure teh clip is fitting into the groove all the way round the edge.
greybing
no,its definatly the actual heat sink thats a tad loose,when my pc arrived ,initially i could pull the heat sink away from the cpu abit so i tightened the screws and it seems fine,the fan had falle off also and it took me a while to get it back on,it was a bugger,its annoying that i cant get an image on my tv ,im just sat here looking at my new pc,unable to go on it.i thought i could maybe get an image with the new vga cable i bought but alas its not the case-is it normal for the pc to not switch off at the power switch,considering ive got no image-whilst trying to get an image i have had to turn it off at the plug 4 times,not good i know..im just gonna wait for my friend now
Sleinous
have you held it down, the power button? The VGA cable should work tbh, I guess youre using teh DVI to VGA adapter? Youre on VGA PC mode on TV?
greybing
ihave just worked out how to switch off ,yeah ,by pressing down for longer-still cant get an image -ive got my pc connected to my tv via a vga cable,no adapter,ive definately got the tv in the right mode-just can not get an image ,ive checked the connections and everything is in place-the g card is in firmly,all my fans spin ,the hard drive vibrates ,the pc apears to boot up withn a little beep ther is just5 no god damn image-im gonna get my mate to bring a monitor so i can see if i get an image with that-if i dont i would assume there would be a prob with graphics card -any thoughts people ,they would be much appreciated- its so annoying i have saved up for my pc from may,just want it to blummin work
Sleinous
U said it beeps twice. This is indeed hardware issue from what i remember? Try taking all RAM out, except one, keep trying this until youve tried each stick seperately (and boot each time).
Gorman
And work it shall, but you not being able to contact us via phone is a big problem.
Things to check:
1. As suggested ensure all ram is seated properly, gently push it into the mainboard, note any travel or clicks.
2. Check the GPU has the correct power cables running to it and the are in securely. If it has, follow the power cables back to the PSU, are they on a molex adaptor? if so make sure it is plugged in securely.
3. Contact tech support!
Gorman
Possibly via Skype if you have any credit?
Unfortunately that was a no go.
Sleinous
Ah yes :( What about an iphone or ipod touch? Any of those lieing around? I would say remote access but I doubt the pc is even booting up so probs nothing to do with the monitor.
Gorman
This is the reason we have tech support, doesnt really work without a phone though :(
Sleinous
I meant, skype through, say, and ipod touch, ye iphone probably doesnt have considering he doesnt have a 'phone' but maybe an ipod touch?
greybing
ok ,tried everything which has been suggested and there has been no luck-the only thing i have not tried yet is with a friends monitor -but this is a hardware problem,is it not ,what with the multiple beep.as for contact through phone -even using a friends mobile is probably out of the question as it would cost me too much -i can go to my mothers house and use hers but i guessed youd need me at the pc -thing is there is nothing more i could add in terms of details over the phone and any suggestions could be made online-anyway my friend is coming round later ,hopefully with a monitor ,he can give his opinion and if after that ither is still no joy -im not sure RMA?
