Can't control Fan Speed on 16" Lafité® AI Intel Ultra 7 155H - Fans are loud on idle
Brinks
I have tried all kinds of fan control softwares...
...and all I could find up to the 8th page on google.
Also I tried the Clevo Control Center which gives me no real options there.
No software is able to detect any fan, just the temperature sensors.
My system specs are:
Housing & display: Lafite series: 16” WQXGA+ 240 Hz N7 LED widescreen, matt (2560 x
1600)
Processor (CPU): Intel® Core™ Ultra 7 16-core processor 155H (up to 4.8 GHz) 24M cache
Memory: 64 GB Corsair 5600MHz SODIMM DDR5 (2 x 32 GB)
Graphics card: Integrated Intel® Arc™ Graphics
1st M.2 SSD drive: 1 TB SAMSUNG 990 PRO M.2, PCIe 4.0 NVMe (up to 7450 MB/R, 6900
MB/W)
Battery Integrated Lafité Pro series lithium-ion battery (73 Wh)
Bluetooth & Wireless GIGABIT-LAN & WIRELESS INTEL® Wi-Fi 6E AX211 + BT 5.3
USB/Thunderbolt options 1 x THUNDERBOLT 4 + 1 x USB 3.2 (TYPE C) + 2 x USB-A 3.2
I don't know any further. I tried to get my hands on Obsidian-PC Fan Control but all sites are taken down and the project has been canceled by the devs. Does anyone run into the same issue of the fans being freaking loud all the time?
Can you post your full specs from the order page?
Laptop fans aren’t like desktop fans, so things like speed fan and fanctrl won’t work
sclough7
I purchased the Lafite Series 16" in December 2024. I had to return it because the fan was so loud.
The fault report I received said:
"We were able to isolate the fault to one of the fans (part of the heatsink) which appeared to be a bit stiffer than expected, possible due to loose bearing. This has been replaced and issue has now been resolved"
