Can it be improved for this price?
gabhau
Hello,
New to PC Specialist.
Profile : Web developer and gamer (Mostly FPS, racing games, Minecraft and Cities Skyline).
Trying to build a new PC. What do you think? For this price range (3000 to 3300 euros), can I get better ? Or as good but cheaper ? I don't mind a +/- 5% increase or decrease in performance.
Ideally the computer should be able to run Linux Debian in dual boot.
System on the 512 GB 960 Pro and storage on the 1 TB card.
COOLERMASTER CM690 III ADVANCED CASE (GREEN)
Intel® Core™ i7 Six Core Processor i7-7800X (3.5GHz) 8.25MB Cache
ASUS® PRIME X299-A: ATX, USB 3.1, SATA 6 GB/s, RGB Ready
32GB Corsair VENGEANCE DDR4 3200MHz (4 x 8GB)
8GB NVIDIA GEFORCE GTX 1080 - DVI, HDMI, 3x DP - GeForce GTX VR Ready!
Get Destiny 2 with select GTX 10 Series GPUs! ** Limited Codes Available **
1st Hard Disk
NOT REQUIRED
M.2 SSD Drive
512GB SAMSUNG 960 PRO M.2, PCIe NVMe (up to 3500MB/R, 2100MB/W)
FREE Assassin's Creed: Origins with select SAMSUNG NVMe SSDs!
2nd M.2 SSD Drive
1TB SAMSUNG PM961 M.2, PCIe NVMe (up to 3000MB/R, 1700MB/W)
1 x 1 Metre European Power Cable (Kettle Lead)
Corsair H100i V2 Hydro Cooler w/ PCS Liquid Series Ultra Quiet Fans
ASUS ROG Xonar Phoebus - exclusive ROG Command technology
France/République Française - French Language
Firefox™
2 DAY DELIVERY TO FRANCE
Price 3 226,00 € including TVA and delivery
URL : https://www.pcspecialist.co.uk/saved-configurations/intel-x299-pc/7pZ9GkMP2a/
Welcome to the forums :)
The i7 7800x has been made more or less obsolete by the i7 8700k, which is overall cheaper and offers better performance.
The onboard sound from the motherboard is quite good. I suggest that you buy the PC without a sound card and try out the onboard sound. You will probably find it to be fine. If not, you can look into options like USB DACs, not just 'gamer' soundcards.
M.2 SSD Drive
2nd M.2 SSD Drive
The 960 Evo is a lot cheaper and offers much of the performance of the 960 Pro.
Also for storage, you could just use an HDD instead of an expensive 1TB SSD.
If you want more than 512gb SSD space, you could buy a 1TB PM961 SSD, and an HDD for mass storage.
Going for a 1TB PM961 and a 2TB 7200rpm HDD, for example, would make the system 264€ cheaper.
Gaming won't benefit from over 16gb RAM. Though of course you are using this for development as well.
Overclocked CPU
Overclocked Intel® Core™ i7-8700K Six Core (3.7GHz @ up to 4.8GHz)
Gigabyte Z370 AORUS Ultra Gaming: ATX, LG1151, USB 3.1, SATA 6GBs - RGB Ready
-Get Destiny 2 with select GTX 10 Series GPUs! ** Limited Codes Available **
1[SUP]st[/SUP] Hard Disk
2TB SATA-III 3.5" HDD, 6GB/s, 7200RPM, 64MB CACHE
M.2 SSD Drive
Price 2 716,00 € including TVA and delivery
Unique URL to re-configure : https://www.pcspecialist.co.uk/saved-configurations/intel-z370-overclocked/XYZ08AcQuB/
gabhau
Thanks Oussebon for your advices :)
I didn't know for the 8700K, so I have to change many things including mother board.
I agree with the sound card, also I'm a music producer so I better lean toward a more professional soundcard.
About the storage I only want SSD. 2x 1 TB M.2 samsung 960 EVO could be okay instead of the 960 pro.
And about the 32 GB RAM, for a web develope it's not too much, 16 GB is acceptable (for the work I do) but not comfortable.
gabhau
Improved configuration, after Oussebon advices. I kept the 960 Pro because there will be a lot of compilation stuff on it, so lot of writes.
Boîtier
BOÎTIER AVANCÉ COOLERMASTER CM690 III (VERT)
Processeur (Unité centrale)
Processeur Six Core Intel® Core™i7 i7-8700k (3,7 GHz) 12 Mo de cache ()
Carte mère
ASUS® ROG MAXIMUS X HERO : ATX, LGA1151, USB 3.0, SATA 6 Gb/s - Compatible RGB
Mémoire (RAM)
32 Go Corsair PREDATOR DDR4 3200 MHz X.M.P (4 x 8 Go)
Carte graphique
8 Go NVIDIA GEFORCE GTX 1080 - DVI, HDMI, 3 x DP - compatible GeForce GTX VR !
Recevez Destiny 2 pour l'achat de certains GPU GTX 10 Series ! ** Codes limités disponibles **
1er disque dur
NON REQUIS(E)
Disque SSD M.2 2242
512 Go Samsung 960 PRO M.2, PCIe NVMe (jusqu'à 3500 Mo/R, 2100 Mo/W)
Assassin's Creed : Origins GRATUIT avec certains SSD NVMe Samsung !
2e disque SSD M.2
1 To SAMSUNG PM961 M.2, PCIe NVMe (jusqu'à 3000 Mo/R, 1700 Mo/W)
Lecteur DVD/BLU-RAY
GRAVEUR DVD DOUBLE COUCHE 24x ±R/±RW/RAM
Alimentation
CORSAIR 750W TXm SERIES™ SEMI-MODULAIRE 80 PLUS® GOLD, ULTRA-SILENCIEUX
Câble d'alimentation
1 câble d'alimentation européen, 1 m (C13/14)
Refroidissement du processeur
Corsair H100i V2 Hydro Cooler avec ventilateurs ultra-silencieux PCS Liquid Series
Pâte thermique
EK-TIM ECTOTHERM PÂTE THERMIQUE
Carte son
HIGH DEF AUDIO (EN STANDARD) 6 CANAUX (5.1) INTÉGRÉ
Connexion Wi-Fi/filaire
CARTE PCI-E WI-FI 802.11 AC1900 1300 Mbps/5 GHz, 600 Mbps/2,4 GHz
Options USB
MIN. 2 PORTS USB 3.0 ET 2 PORTS USB 2.0 SUR PANNEAU ARRIÈRE + MIN. 2 PORTS EN FAÇADE
Système d’exploitation
SYSTÈME D’EXPLOITATION NON REQUIS
Langue du système d’exploitation
France/République Française - Français
Logiciel Office
PAS DE LOGICIEL OFFICE
Antivirus
PAS D'ANTIVIRUS
Navigateur
Firefox™
Garantie
Garantie Platinum de 3 ans (3 ans de garantie collection et retour atelier, 3 ans de garantie pièces, 3 ans de garantie main d'œuvre)
Livraison
2 JOUR LIVRAISON EN FRANCE
Délai de construction
Assemblage standard - Environ 7 à 9 jours ouvrables
Prix 3 105,00 € livraison et TVA compris(e)
URL unique pour reconfigurer : https://www.pcspecialist.co.uk/configurations-sauvegardées/intel-z370-pc/tH4fNpA5eM/
You can customise the spec how you like with the link above, ofc :)
2 x 1TB PM961 SSDs are only 38€ more expensive than a 512gb 960 Pro + 1TB PM961.
gabhau
I see that Intel 8700K uses an older socket (LGA1151) than the 7800X (2066). I want my system to be evolutive, so maybe it's better to choose the Socket 2066 with 7800X, even if the 8700K is more powerful and a bit cheaper.
About the motherboard, I'd like to make a SLI one day so need two PCI Express 16x.
I still ditched the soundcard.
This is the config I have right now:
Boîtier
Processeur Six Core Intel® Core™ i7-7800X (3,5 GHz) 8,25 Mo de cache
Carte mère
ASUS® PRIME X299-A : ATX, USB 3.1, SATA 6 GB/s, compatible RGB
Mémoire (RAM)
32 Go Corsair VENGEANCE DDR4 3200 MHz (4 x 8 Go)
Carte graphique
1er disque dur
NON REQUIS(E)
Disque SSD M.2 2242
2e disque SSD M.2
Lecteur DVD/BLU-RAY
Alimentation
Pâte thermique
Carte son
HIGH DEF AUDIO (EN STANDARD) 8 CANAUX (7.1) INTÉGRÉ
PORT 10/100/1000 GIGABIT LAN (Wi-Fi NON INCLUS)
Options USB
MIN. 2 PORTS USB 3.0 ET 6 PORTS USB 2.0 SUR PANNEAU ARRIÈRE + MIN. 2 PORTS EN FAÇADE
Support de récupération sur DVD
SUPPORT DE RÉCUPÉRATION SUR DVD NON REQUIS
Logiciel Office
Antivirus
PAS D'ANTIVIRUS
Navigateur
Firefox™
Garantie
Livraison
Article promotionnel
Quantité
Prix 3 052,00 € livraison et TVA compris(e)
URL unique pour reconfigurer : https://www.pcspecialist.fr/configurations-sauvegardées/intel-x299-pc/qqhwbbUcb!/
No.
First, although the socket is called 1151, the 8700k is newer than the 7800x. Also, the 8700k isn't compatible with older 1151 socket motherboards.
And the 7800x gives lower performance in gaming - everything gives lower performance vs a 8700k:
For a really wide range of benchmarks including many professional applications, see Anandtech: https://www.anandtech.com/bench/product/2025?vs=1903
The 8700k is better/faster at pretty much everything.
No, you do not. It makes no difference running the GPUs of PCIe slots that are x16 or x8:
https://www.gamersnexus.net/guides/2488-pci-e-3-x8-vs-x16-performance-impact-on-gpus
https://linustechtips.com/main/topic/502425-x16x16-vs-x8x8-sli-resultsawkward/
https://www.techpowerup.com/reviews/NVIDIA/GeForce_GTX_1080_PCI_Express_Scaling/17.html
The PCIe lanes x16 vs x8 just don't bottleneck gaming performance. You do not need loads of PCIe lanes for SLI.
To quote Gamersnexus:
The difference is not even close to perceptible and should be ignored as inconsequential to users fretting over potential slot or lane limitations.
Honestly, it sounds like you are trying to find reasons to buy the 7800x just because it is more expensive and sounds like it should be better. But it simply is not.
