Can I really have a 2nd HD? (Enigma III)
AESamuel
Hey,
I was just browsing the upgrade options for my Enigma III laptop and it says I can get a 2nd hard drive. I would love an SSD to go along with my normal hard drive but I can't for the life of me work out where it would go. I've located the hard drive on my laptop and there isn't space for another.
Would it replace the CD drive or something? What would I need to allow me to do this?
Cheers,
AESamuel.
tom6561
Yes it would replace the DVD drive - you'd need to get a caddy from PC Specialist, then you just need a screwdriver!
vanthus
Member Resting in Peace
Bit more to it than that really If you want the operating system on the SSD,not much point getting one otherwise.Best take the existing hard drive out and replace it with the SSD then install the OS on the SSD,then install the old hard drive to the DVD bay.Back up any important data files before formatting the HDD from the OS on the SSD.
