Cable Management
M4RINE007
I have looked around the FAQ's and had a look at the customization options and I haven't seen a cable management one.
I don't whether this is the right place to ask but it seems like it so is cable management default and done free by PC Specialist?
nathanjrb
PCS do all your cable routing, yes.
Good job too otherwise I'd be trapped in spaghetti junction.
tom_gr7
Life Serving
yeah its included in the price. However, its clearly linked to the quality of the case. ie, the better the case, the better the cable management, the better job PCS can do. So, if you get a smallish low end case, with a high end system inside, the cables aint going to be as tidy and as "managed" as the same system in a top of the range case would be. - If that makes sense.
i'd, also argue that it depends on what PSU you choose too. But i think that just me being picky.
