Buzzing Noise When Playing Games
Pepsi_Jamie
Hi all,
I recently reset my laptop to factory settings and everything went perfectly. However, I've noticed that whenever I'm playing a game with my laptop's charger plugged in, there's a noticeable buzzing noise. I've uninstalled then reinstalled my audio drivers in an attempt to fix the problem, but it didn't work. As I mentioned, it seems to generate the buzzing noise whenever I have my charger plugged in. I'm not sure what's causing it, but any solutions would be greatly appreciated.
Update: After further research of possible solutions, I found a website asking me to check my GPU for buzzing noises when in use. After loading up 2 different games with my GPU active, it was definitely making a buzzing noise. As soon as the applications closed, the buzzing noise stopped. I really haven't got a clue what's going on.
Specs:
Intel Core i7 - 4940MX 3.10 GHZ
32GB RAM
Nvidia GTX 980M
Samsung EVO 1TB
Windows 10 64-bit
steaky360
I guess it could be a few things, does the buzzing sound like its coming from the speakers? Or is it from the chassis itself?
If its the chassis it could be a fan spinning up (which ties into it only happening during gaming).
If you're feeling confident you can likely take the back off the laptop and see if anything needs a bit of a clean/dust or perhaps something is stuck in one of the air intakes etc?
Steve91
It sounds like it could be coil whine, which could be coming from the GPU. This is a common occurrence when running high intensity GPU workloads. As an example, I notice it with my PS4 Pro when playing games at high frame rates. The problem goes away when I’m on the dashboard, though. Unfortunately, I don’t know a fix for this issue.
However, as mentioned above, a simple cleaning of the internals may be all that’s required.
