Buying on friday
JustNatsu
It's finally that time i've gathered up the funds to actually upgrade my pc. And plan on purchasing it on friday. The intended use its large multi tasking such as gaming,skyping,youtube,steaming,recording all at the same time. My budget overall for the pc is £2.5k let me know if you think i should change anything below thanks. I have chose to select my own grapghics card as im intrested in the gtx 1080ti strix and unfortunately pcspecialist only has an option of 2.
CORSAIR CRYSTAL SERIES 570X RGB GAMING CASE
AMD Ryzen 7 1700X Eight Core CPU (3.4GHz-3.8GHz/20MB CACHE/AM4)
ASUS® PRIME X370-PRO (DDR4, 6Gb/s, CrossFireX/SLI) - RGB Ready!
16GB Corsair VENGEANCE DDR4 2133MHz (2 x 8GB)
NONE, I ALREADY HAVE A GRAPHICS CARD (GTX 1080 ti STRIX)
1st Hard Disk
NOT REQUIRED
2TB SATA-III 3.5" HDD, 6GB/s, 7200RPM, 64MB CACHE
M.2 SSD Drive
500GB SAMSUNG 960 EVO M.2, PCIe NVMe (up to 3200MB/R, 1900MB/W)
NOT REQUIRED
CORSAIR 650W TXm SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Corsair H100i V2 Hydro Cooler w/ PCS Liquid Series Ultra Quiet Fans
Price £1,465.00 including VAT and delivery
£2,235.00 (with the strix graphics card)
It looks great.
If you are happy installing your own RAM I'd suggest buying the build with the minimum 4gb and fitting your own 3000MHz/2933MHz kit, since Ryzen can benefit decently from faster RAM for gaming.
I assume you'll be overclocking your CPU? If not a cheaper cooler would be fine.
If SLI is something you might consider in the future, an RM850x PSU would be worth getting. It's also a very good PSU in its own right.
JustNatsu
yeah i was wondering why the ram i could pick was pretty low in compassion to whats available for the intel side of things o pc specialist. So ill take your advice for that one one thanks and get my own ram. and i think ill just go for the psu as well just incase thanks you
Make sure to read up on what's compatible with the mobo and maybe get some advice on a forum or reddit for what's likely to play nice. There was someone on this forum who tried the above with a kit that for all the world looked like it should have been able to run at 2933MHz but they couldn't get it past 2666MHz. Still better than 2133MHz, but I'm not sure how much expertise there is on this forum with Ryzen and various non-PCS RAM kits, so do make sure you've looked into stuff before buying. :)
