Buying a desktop (£650 budget)
HCFC_CLARK
Hi everyone,
I need some help buying a new PC.
I have a budget of around £650, and im looking for a good all round PC that is also capable of a bit of gaming (Football Manager, The Sims, The New Sim City & maybe a few others).
I've been looking around, and im no whizz, but the Dell XPS 8500.
Link: [edit by Rakk: no competitor links please]
Processor
3rd gen Intel® Core™ i7-3770 Processor (3.40GHz, 8MB)
Windows 8 64bit, English
Monitor
Display Not Included
Memory2
8GB3 Dual Channel DDR3 SDRAM at 1600MHz
Hard Drive
1TB Serial ATA (7,200 rpm)
Video Card
AMD Radeon™ HD 7570 1GB DDR5 Graphics Card
Optical Drive
16x DVD +/- RW Drive (read/write CD & DVD)
Keyboard
Dell KB213 USB Multimedia Keyboard - UK/Irish
Wireless
Dell Wireless 1703 802.11b/g/n, Bluetooth v4.0+LE
Security Software
Microsoft Windows® Defender Included
Services and Support
1 yr Next Day In-Home Hardware & Premium Software Phone Support
Advertised System Weight
12.86 kg.
Price = £650
If anyone could say weather this is good for the price, and if not, something that would suit my needs for a similar price please.
Thanks guys, can't wait to hear what you have to say!!
vanthus
Member Resting in Peace
InWIN MANA-136 BLACK GAMING CASE
AMD FX-4170 Quad Core CPU (4.20GHz/4MB CACHE/AM3+)
ASUS® M5A97 R2.0 (DDR3, USB3.0, 6Gb/s, Windows 8 Ready!)
4GB SAMSUNG DUAL-DDR3 1333MHz (1 X 4GB)
2GB AMD RADEON™ HD7850 - DVI,HDMI,2 mDP - DX® 11, Eyefinity 3 Capable
450W Quiet 80 PLUS Dual Rail PSU + 120mm Case Fan
Super Quiet 22dBA Triple Copper Heatpipe AMD CPU Cooler (£19)
WIRELESS 802.11N 300Mbps PCI-E CARD (£16)
Genuine Windows 8 Standard Edition 64 Bit - inc DVD & Licence (£79)
FREE 60 Day Trial of Microsoft® Office® 2010 Professional Edition
LOGITECH® K200 USB MEDIA KEYBOARD (£10)
Price: £681.00 including VAT and delivery.
HCFC_CLARK
Thanks for the quick reply mate. What sort of game would this be capable of playing? Also, is the XPS 8500 way over priced?
Rakk
The Awesome
The PCS machine Vanthus has specced up will play games much better, the GPU in the Dell one is pretty old now (in fact its worse than my GPU by quite a way I think and my GPU is two and a half year old already), the 7850 one that vanthus suggested is far superior, and since most current games depend heavily on the graphics card, that's where you'll see the difference.
The PCS machine has a lesser CPU, but to be honest unless you're playing games that use the CPU a lot, the i7-3770 just isn't really needed, the CPU vanthus suggested will be perfectly fine. Also you'll probably be getting a slightly nicer hard drive which will make it a little faster - and for your budget the AMD processor fits in nicely.
mikef
The Dell will be OK if you don't want to upgrade key components during its life. If it's like the 8100, it will have proprietary Dell motherboard and an (odd sized) power supply which is just sufficient for the components it ships with. The PCS build (personally I would look for an Intel-based alternative) will have plenty of scope for future upgrades.
Also - you won't get original Windows media with the Dell, the warranty will be much more expensive and the "support" will be offshore and geared toward selling you further services.
HCFC_CLARK
Can anyone reccomend an improvement on the build vanthus provided? Whats the difference between Intel and AMD processors?
Decided to go against the Dell, you guys seem to know what your talking about so thanks for the help.
vanthus
The AMD processor will be fine running the games you mentioned and also for the vast majority of games out at the moment.I myself have an AMD processor and can recommend it,best bang for buck by far.Also as mentioned by Rakk the 7850 is by far a better GPU than the 7570.
HCFC_CLARK
2nd opinion on this desktop
Just wanted people to give a 2nd opinion on this build before I order (credit to vanthus for reccomending this to me).
It is intended for all round use and a bit of gaming too, the likes of Football Manager, The Sims and a few others (BF3 etc. would be nice if possible.)
Anyway, here is what he reccomended, a 2nd opinion would be nice.
Rakk
The Awesome
The spec looks pretty good to me
And yes, I merged your two threads, its easier if you keep it all in one thread, means its easier to see the different responses and also means people are not answering the same thing twice :)
HCFC_CLARK
Just wanted to say i've ordered this! Removed the keyboard so it was £671 in total, thanks very much to vanthus for helping me out!
Grimezy
Just a quick amendment you might want to make, I would up the ram to 8gb if you can squeeze that in the budget. It shouldn't cost too much more. 4gb is fine for most things but I have noticed that on some recent games the recommended ram is either 4gb or 6gb. Not sure on the specifics and whether a recommended 4gb game actually means you only need 4gb total or 4gb free at all times purely for the game but I would go for 8 to be safe if possible. This will also allow for better multitasking if you like browsing in the background while you have games running, etc. Entirely your choice though :) 4gb would probably be fine, it's just not too expensive of an improvement if you do choose to do it.
Edit: Just looked back at your spec and you could potentially knock the hard drive size down to 500gb to upgrade the ram if you fancied it. It depends how much you plan to install though. I got the 1tb caviar black and have used 150gb in 2 weeks purely on games but I also have a 2tb external hard drive plugged in for all my other files. Depends if you plan to cram it full or whether you could make do with 500gb for games and buy an external hard drive later on for other things!
HCFC_CLARK
Thanks for the advice mate, for £19 extra to double the RAM I may as well. Cheers!
Grimezy
Haha and so the amendment phase begins! You'll start finding lots of little additions now to put on thinking "ah twenty quid, why not!" just because it's easier to digest than having them when you originally place the order!
On a serious note though, that ram should be well worth £19 :) Good luck with waiting for your rig!
HCFC_CLARK
Nope, that is it haha! I cannot afford anymore, so the only changes now will have to be a result of a downgrade in another area.
Thanks for the help off you both tho, helped me a lot so I gave you both rep!
HCFC_CLARK
So I've been looking at ordering 2 monitors and I read that you need to check that your graphics card can accommodate this. Can anyone tell me if mine will be okay?
Also, what sort of components will I need to run 2 monitors? I'm guessing 2 HDMI cables but will I need anything else?
vanthus
The 7850 is perfectly capable of running two monitors,you only need the cables,what cables you need will depend on the ports your monitors and GPU has.
