Hey guys,
I'm currently on day 11 of pre-production for the following gaming build.
Starting to have second thoughts on my choices and would like to ask you guys for your opinion, please.
Currently have a Dell P2721Q - 4k monitor 60hz
(Not ideal for gaming, but it's a first gaming PC and I'll upgrade the screen in the months to come to something more fitting for a 3070ti.)
I have two things I would really like to hear your thoughts on. (Obviously, if you have any other suggestions, I'd love to hear them)
1. CPU - 3700x vs 5800x vs 5600x (paired with 3070ti)
2. Wifi/Motherboard - For the first few months I'll be needing to use wifi, have a 500mbps connection.
- Should I go with an external wifi card as listed in the spec, and a non-wifi motherboard? or change to b550 plus wifi.
Link to re-config:
AMD Ryzen 7 3700X Eight Core CPU (3.6GHz-4.4GHz/36MB CACHE/AM4)
8GB NVIDIA GEFORCE RTX 3070 Ti - HDMI, DP
512GB INTEL® 670p M.2 NVMe PCIe SSD (up to 3000MB/sR | 1600MB/sW)
Corsair H115i RGB PRO XT Hydro Series High Performance CPU Cooler
NO RECOVERY MEDIA REQUIRED
Mouse Pad
PCS Mouse Mat - XXL
Surge Protection
6 Socket 2m Surge Protector
Cable Management
PCS 1.5M Zip Cable Tidy - Professional Cable Management
Standard Build - Approximately 18 to 21 working days
Link to re-config:
PCSPECIALIST - Top Spec Custom PCs & Laptops Built to Order
Manufacturer of performance custom computers and laptops. Customise your ideal gaming PC or laptop using our advanced configurator.
www.pcspecialist.co.uk
Mouse Pad
PCS Mouse Mat - XXL
Surge Protection
Cable Management
