Hey,
I'm looking to build a PC which will power through AE projects primarily but allow flexibility to modify and cope with more 3D in the future.
I have always used pre-builds in the past so am a but out of my depth and need some guidance!
TASKS
90% After effects (mostly HD, some UHD and relatively complex projects with some GPU hungry plugins)
10% AI, PS, C4D
Future flexibility for more work in C4D and/or Blender etc.
BUDGET
£2,500-£3,000
Happy to hover around the top and of that if a good monitor solution is included.
MONITOR
Top speeds not essential as mostly 24/30 fps animation/motion graphics
I have limited space so preferably looking for a single monitor set up - 32"-34"?
Thought I wanted curved but may well be misguided on that.
STORAGE
Probaby 1TB NVMe for projects & 1TB for system/software files (more would be nice if budget allows)
PROCESSOR
I have only ever used Intel processors - are AMD really that much better?
In my first punt spec (below) I have ramped up the core count to take advantage of multi-frame rendering but I'm pretty sure I have gone a bit over the top!
So do I need a more balanced CPU with a higher single core clock speed?
Like I said, the spec below is a first punt so feel free to correct any wild assupmtions I might have made.
Thanks in advance for any advice,
Neal
COOLERMASTER MASTERBOX MB540 ARGB GAMING CASE
Intel® Core™ i9 18 Core Processor i9-10980XE (3.0GHz) 24.75MB Cache
ASUS® ROG STRIX X299-E GAMING II: ATX, USB 3.2, SATA 6 GB/s, Wi-Fi AC - ARGB Ready
128GB Corsair VENGEANCE RGB PRO DDR4 3200MHz (8 x 16GB)
2GB NVIDIA GEFORCE GT 1030
Corsair H150i ELITE CAPELLIX RGB Hydro Series High Performance CPU Cooler
Speakers
LOGITECH Z200 2.0 SPEAKERS - 10W
Logitech® HD Webcam C920 - 1080p recording & 720p video calling
Price: £2,955.00 including VAT and Delivery
TASKS
10% AI, PS, C4D
BUDGET
£2,500-£3,000
MONITOR
STORAGE
PROCESSOR
Neal
Speakers
