Build me a gaming desktop!
walkington
Can someone build me a gaming desktop! for around £900?
i would like it to be best for gaming so anyone in the know how please help
SrgColman
ASUS® P8P67 (NEW REV 3.0): USB 3.0, SATA 6.0GB/s, CrossFireX™
1.25GB NVIDIA GEFORCE GTX 570 - 2 DVI, HDMI, DP - 3D Vision Ready
500GB WD CAVIAR BLACK WD5002AALX, SATA 6 Gb/s, 32MB CACHE (7200rpm)
CORSAIR 650W TX SERIES (TX650) 80+ ULTRA QUIET PSU (£72)
Price: £900.00 including VAT and delivery.
Configure Here: http://www.pcspecialist.co.uk/computers/intel-sandy-bridge-pc/
But for your budget you might want to consider going with the HD6950 for a GPU, could use the money saved to upgrade whatever parts you want, to a nicer Case or maybe a bigger Hard Disk
Wozza63
Biblical Poster
id recommend getting a better case, the PCS Maelstrom T900 is a very popular choice for those on a strict budget
wereireland
Well heres my suggestion. By going with AMD you can get a 8GB ram at 1600 MHz so it would perform much better.
AMD PHENOM II X4 970 (3.50GHz/8MB CACHE/AM3) - BLACK EDITION
ASUS® M5A99X EVO:USB 3.0, SATA 6.0Gb/s, Quad CrossFireX™/SLI™
8GB KINGSTON HYPER-X GENESIS DUAL-DDR3 1600MHz (2 x 4GB KIT)
Price: £901.00 including VAT and delivery.
Configure Here: http://www.pcspecialist.co.uk/computers/amd-top-spec-pc/
TrustMeItsWorthIt
You really wont see the difference between the 1600Mhz and the 1300Mhz, the 1600Mhz is really only for OCing for normal use you may as well go for the 1300Mhz imo
DeadEyeDuk
Superhero Level Poster
Ultra settings might be a push, especially for hungry hippos like Witcher 2, but will still work fine for a time to come :)
