Build and questions
PadForce
Hi all, I just wanted any opinions on the build below, purely for gaming, currently on a 22" screen but considering a 27". I am sending in my own Coolermaster case, power supply, blue ray and HDD (for storage, boot and main game or 2 will be on SSD).
Main question is should I wait for the 4gb GTX 680 to become available? I have read a lot of discussion and it seems some people think that 2gb will cause a bottleneck in the future, possibly after 12 /18 months. I was planning to SLI when 680s become cheaper in a year or twos time, but apparently SLI-ing does not double the V-ram. Apart from this I did not want to upgrade for another 3 years or so and would be disappointed if I found myself bottlenecked after a year and a half when trying to nail high settings.
Send In Your Own Case
Intel® Core™i7 Quad Core Processor i7-3770K (3.5GHz) 8MB Cache
ASUS® P8Z77-V PRO: PCI-E 3.0 READY,WIFI, SLI, CROSSFIREX
350W Dual Rail PSU + 120mm Case Fan
2 x 200Mbps HomePlug AV - Create a Wired Network Using Electric Sockets! (£38)
Price: £1,327.00 including VAT and delivery.
baron75mk2
Banned
Check this out http://www.geforce.com/hardware/desktop-gpus/geforce-gtx-680/specifications
You will need a bigger psu for this GPU minimum is 550w - i would go for a 850w so you can do SLI in the future ,
As far as bottlenecks in the future i really couldnt say , but at the moment im running 2X GTX580s 3gb models (SLI) - (faster than a single GTX 680) on a Sandy i5 2500k with 8 gig of 1600mhz ram & i have no battlenecks from what i can tell ( well i play everything at max settings with 60fps at all times at leased) - couldnt say for 2 or 3 years down the line , its tough to know whats around the corner by then ,
Most pc games are limited by console porting these days , so if this is the same in the future , there are whispers that the new xbox will be using an equivilant of the radeon 7XXX series - other rumours suggest even a dual chip 7XXX series ( this is all rumour so make what you will of this , but these are current gen gpus & the rumors for the processor is a 6 core , with 1 core reserved for kinnect & one core for the os, so leaving 4 cores for the games , speed ? who knows ? but i cant personally see them going much higher than they are now , as with these consoles cooling is so bad they are always overheating & packing up as it is) ( where is the cooling going to be housed for hotter chips ? - or maybe chips a few years down the line will operate cooler ? who knows ? - 2 or 3 years down the line is very hard to predict really) - but if these rumors are true im not worrying myself to much. :yes:
& no SLI does not double the ram
Fear
I am thinking you may have missed this part from the OP ;)
baron75mk2
Banned
Being it was listed , i presumed that was the power supply he / she was sending in . As in the case discription it did say "sending in own case" , but not for psu , so i presumed that was the one being sent in.
MY mistake :yes: ( i suppose anyone reading the post will at leased have general idea of a suitible PSU for the GTX 680 :yes:)
PadForce
Ha yeah sorry for the confusion, can't select no psu in the configuration. The psu I am sending in is in fact a corsair 850.
Baron my worry with the v-ram is that your 580's have more than my 680 would. Sli-ing later on would not boost the ram if I'd does turn out to bee a problem over the next 1-2 year period based on new games so I would be left having to go totally new graphics card.. Probably a waste given the £450 of the 680.
baron75mk2
Banned
yes SLI will not give you more ram at all , but my suggestion was to dump the GTX 680 & go with the GTX 580 in SLI ( 3gb models) as at the moment its beating the GTX 680 ( single card that is , wont beat two of them - lol)
But on reflection this is good for now , but probably not so good in the future as obviously if your thinking of Taking 2 GTX 680s in SLI then this will beat any GTX 580 setup - possibly waiting for the 4gb GTX 680 would be the best bet , this way all the basses are covered.
Just wondering why so much v-ram needed ? - do you play across 2 or 3 monitors , in 3d etc ? , if not 2gb should be quite adiquate across 1 screen even for the future in my opinion , i can only think of a few games at the moment that even swallow a gig ( GTA4 , battlefield 3 , witcher 2 - none of these get above 1400meg even at max settings) & i cant see any game swallowing 2 gigs of v-ram even in the future ( but again its hard to predict the future of games i suppose),
only thing you could consider is what i have done 2x GTX 580s SLI (3gb models) for now & when Nvidia 7XX series come out , buy 2x GTX 680s a lot cheaper & keep doing this , sure you will always be a generation behind - but then they are never that far in front of each other anyway , i was in fact going to get a GTX 680 myself , but decided ON the GTX 580 SLI setup & im not disapointed at all , i cant see any game in the near future at leased that`s going to shake this setup really ( remember for the most part us pc gamers are limited by console porting) ( games developers mainly concentrate on console when making a game as for better or worse there is more money to be made in just making a console version & simply porting it over to pc , thus saving them the money & hassel of having two seperate builds going at the same time) (apart from the odd pc specific build like witcher 2 maybe , but these are few & far apart these days indeed ) :yes:
Its just to hard to predict what`s going to be on the cards in 2 years time , everythings always changing to fast :yes:
PadForce
It is not that I have huge screens or multi, I just want don't really want to run the risk that in a year or two I am not restricted by the ram when paying so much for the card.
How about a 7970? It is £75 cheaper and most benchmarks seem to indicate the cards are not massively different? I would then be able to crossfire for cheaper later on and have that 3gb of memory and could sli in the future to address higher requirements.
baron75mk2
Banned
Well from everything i have read the HD 7970 is an exellent card & well worth considering , im sure there is someone around here who could give you first hand knowledge on this card.
Just a small note on crossfire , just before i got the GTX 580 SLI setup i did in fact have a HD 5850 crossfire setup & had a lot of issues im not encountering with sli at all , the main issue being whenever playing a game with video sequences the video would always split up ( screen tear ) , but the 3d would not ( exept for a few bits in mass effect 2 that is) , but on one card there was no splitup at all - but the same games on SLI do not exibit this at all.
The only reason i bring this up is when i was searching for a solution on line i remember reading a post where someone with a 7970 was getting the same issue in crossfire - it could just be that the HD5850s are no good in crossfire - but im sure i remember reading the post about the 7970 with the same issues in crossfire & believe me theres nothing worse that having to turn off a card for half of your games due to split up in the video sequences.
( i remember someone talking about the reason for it has something to do with the ati drivers power management clocking down on one card mid game when the video came in , but not on both cards (makes sence in a way as one would be running at a totally different speed to the other card , thus they would not be synchronized up i suppose)
May be worth some ferther research before deciding - but if your just running one 7970 dont worry about it.
PadForce
Thanks for your replies baron - ordered the above spec last night with a 7970 and justified a 27" screen as well from all my savings. £1500 on the button including home plugs, now the exciting wait!
baron75mk2
Banned
Its going to be an awesome rig , i dont think you will be disapointed ,the HD 7970 is a great GPU ( on its own anyway ) , you should be stomping all over any game out there ( posaibly not battlefield 3 or witcher 2 as uber SLI / Crossfire setups are needed to max these games out & get 60fps at all times .) As far as battlefield 3 goes just turn off ambient occlusion & AA , for witcher 2 just turn off ubersampling ( kills the game even in SLI & really does not give any visual improvement as witcher 2 is not a jagged game anyway so no need for crazy AA like this ) & AA & you will be getting 60fps at all times ( i tested them both before i got my second GTX 580)
A very nice build indeed , would be intersting to hear your thoughts on it when you have benched it with a few games - :yes:
