Build advice
dmriddell
looks like this
PCS SPECTRUM RGB MID TOWER CASE (WHITE)
Intel® Core™ i9 10 Core Processor i9-10900X (3.7GHz) 19.25MB Cache
ASUS® PRIME X299-A II: ATX, USB 3.2, SATA 6 GB/s, ARGB Ready
32GB Corsair VENGEANCE DDR4 2400MHz (2 x 16GB)
12GB NVIDIA GEFORCE RTX 3060 - HDMI, DP
256GB PCS 2.5" SSD, SATA 6 Gb (500MB/R, 400MB/W)
128GB PCS PCIe M.2 SSD (1000 MB/R, 600 MB/W)
CORSAIR 550W CV SERIES™ CV-550 POWER SUPPLY
PCS FrostFlow 150 Series High Performance CPU Cooler
LED Lighting
50cm White LED Strip
2 PORT (2 x TYPE A) USB 3.0 PCI-E CARD + STANDARD USB PORTS
Capture/Streaming Cards
AVerMedia Live Gamer HD 2 - PCIe Card
looks like this
LED Lighting
I would STROngly recommend getting some advice, that’s a really poorly specced build for any use.
The case is no where near suitable for the components and will lead to throttling.
The CPU is awfully poor, last generation and hugely expensive for weaker performance.
It’s a redundant X299 platform that has zero upgradeability.
Extremely slow RAM that will be a bottleneck
Weak and small PSU that isn’t suitable and prevents any upgrades
Cooler isn’t appropriate for the cpu
Basically the whole build doesn’t fit well together at all for any use.
Check out this thread, especially the section on AMD v intel
dmriddell
Thank you! Unfortunately it looks like they only have Intel in stock atm, but is there a PSU and cooler that you would recommend ?
Steveyg
This build needs a lot of help, I'm not sure what you mean by them only having Intel stock they keep stock of both CPU's and have a steady stream of supply. CPU lead times isn't much of an issue anymore it's the GPU where the delays are really taking affect
Can I ask what your budget is, what monitor you'll be using and what the computer will be used for and we can help you get something much better for your money?
The AMD configurator is here, have you ordered the above if so i suggest you cancel it,
What do you mean? There’s no issues with AMD stocks, almost everyone is buying AMD because they’re years ahead of intel for the same cost.
I would strongly recommend getting an AMD build together and calling up and asking if you can switch to it.
I can’t stress enough that what you’ve ordered isn’t going to be good at all.
dmriddell
Sorry, I mean I can only select Intel when amending the order:
Steveyg
Yeah you're better completely cancelling the order and starting again
You can only select Intel when amended because you've gone with an Intel build. You would need to start again with an AMD system to get AMD CPU's
You pick one or the other they aren't interchangeable
That’s because your on an intel configurator. You can’t amend your current build, it’s on an obsolete platform. You’d have to get a quote for a decent AMD build then call up and ask them to switch to it.
dmriddell
Sure! I’m using a HP monitor atm, and usage will be split between photoshop for work & streaming/gaming as a hobby.
I initially paid just over £2k, but my budget is £2.5 if that helps?
Also re: the CPU, I just replied below but I can’t seem to see the AMD as an option when amending the order!
dmriddell
Ah, okay gotcha!
Steveyg
With that kind of budget you could go for a monster like this, I went for the higher end CPU simply because you had an i9 but I'm not entirely sure you need it? You still haven't told us what the build will be used for but the below is what you should be looking for in that price range
CORSAIR 5000D AIRFLOW TEMPERED GLASS GAMING CASE
8GB NVIDIA GEFORCE RTX 3070 - HDMI, DP, LHR
Firefox™
Price: £2,422.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/AdxfsK4Y9r/
dmriddell
Okay that sounds like a plan — I’m outside of the 14 cancellation at ths point
Firefox™
Amazing, thank you!
I think it got buried above haha — I’m using it for work (Adobe programs mostly) and live streaming / gaming as a hobby which is why I had gone for the 12GB graphics card.
create a quote using the @Steveyg build above, make a note of the quote number, then phone them up and explain that you'd like to change your order to the new quote
dmriddell
So with @Steveyg's recs, does this look better?
NZXT H511 MID-TOWER GAMING CASE (WHITE)
12GB NVIDIA GEFORCE RTX 3060 - HDMI, DP (Pre-Order Only)
Get Resident Evil Village with select Samsung SSDs
2nd M.2 SSD Drive
Firefox™
