Hi everyone. After reading the forums for some time I decided to go with the bellow specs and would like to have your opinions on this. Many thanks to Oussebon who made a few suggestions. The build will be used for gaming(nothing extreme) and some programming. The cost of this build is £1329 which is at the top end of my budget but can spend a little more if it will be worth it in the long run. I am planning to add a SSD myself when the budget will allow it. Got one of the Samsung NVME drives in my Defiance II and will probably remain loyal to the brand. Will I need any extra case fans? Have not owned a desktop in ages and I am not too familiar with the concept.
Also, can anyone recommend a budged friendly keyboard and mouse? Preferably around £50-75 mark, less if possible. I tend to play games like Dota 2, Counter Strike, GTA V.
Another thing that just came to mind, what do you guys think of the monitor? Should I stick with the ASUS or should I choose something between AOC G2460PF 24"/IIYAMA GB2488HSU-B2 24"/BENQ ZOWIE XL2411 24". I read a few reviews but could not find any made by the same website to draw a comparison.
FRACTAL DEFINE S BLACK GAMING CASE (Window)
Overclocked CPU
Overclocked Intel® Core™i5-6600K Quad Core (3.50GHz @ upto 4.60GHz)
ASUS® Z170-E: ATX, LG1151, USB 3.1, SATA 6GBs
16GB HyperX SAVAGE DDR4 3000MHz (2 x 8GB Kit)
6GB NVIDIA GEFORCE GTX 1060 - DVI, HDMI, 3 x DP - GeForce GTX VR Ready!
1st Hard Disk
NOT REQUIRED
CORSAIR 650W CS SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
DVD Recovery Media
NO DVD RECOVERY MEDIA REQUIRED
Monitor
ASUS VG248QE 24" 3D 144Hz GAMING DISPLAY
Promotional Item
FREE HOLIDAY SEASON BUNDLE with select GTX 10 Series GPUs!
Overclocked CPU
1st Hard Disk
NOT REQUIRED
DVD Recovery Media
Monitor
Promotional Item
