Buget build £500
nitesh45
Mainly used for Microsoft office work, playing minecraft and running minecraft server, multi tasking and Surfin the web
pr1s0ner
but if you stick with AMD processors and graphics cards you should be able to get something that will keep up with the requirements you've listed
Petchi b
This is about the best you can get for your budget. It should be fine for your needs.
AMD PHENOM II X2 DUAL CORE 565 (3.40GHz/6MB CACHE/AM3)
ASUS® M5A78L-M/USB3: M-ATX, USB 3.0, SATA 3.0Gb/s
1GB AMD RADEON™ HD6770 - DVI,HDMI,VGA - DX® 11
1TB SERIAL ATA 3-Gb/s HARD DRIVE WITH 16MB CACHE (7,200rpm)
STANDARD AMD CPU COOLER
4 x USB 2.0 PORTS @ BACK PANEL (MIN 2 FRONT PORTS) AS STANDARD
Price: £492.00 including VAT and delivery.
