Segwayrider
Overview
**budget:** 700-1000£
**Use case:** Mainly sims 4 and light gaming. Not more than 1080p, 60 fps
**Monitor:** None. Not included in budget. Probably some small 24-27”, 1080p, 60 hz monitor
Hello
My sister has asked me to try to build her a system for about 700£ ( 7000 ddk).
She manly plays sims 4 and just want something that is quicker and more responsive than her current all in one pc. Due to the budget, I cannot imagen anything above 1080p. Her main requirement is the case which need to be a white FRACTAL NORTH TG gaming case. Otherwise, she does not care too much. Her current all in one is a windows pc and I plan on helping her getting the license from it.
She would also need at the very least a screen, but that does not include in the given budget. (I might be able to gift her my 24” 60 hz 1080p screen)
Now I’ve tried a bit, and maybe I’m just a snob when it comes to components and what I would be comfortable with, but I haven’t found anything that comes close to that budget. Maybe 1000£ but still not something that I feel confident enough in to suggest.
The best I have is this, where i would need to go out and buy a probably used graphics card somewhere
https://www.pcspecialist.dk/gemte-konfigurationer/amd-am5-pc/SyvqHQsMK6/
So are there anyone with better knowledge than I, that can pull out some magic, or is my sister better of saving up for now?
For reference this is more like something i would offer her, both in terms of spec but also cohesion in looks, though way over bugdet. Also this is from an add I saw where I cannot change the ram down to 16 gb. Many of the parts seems unaviable from the standard "costumize a desktop pc" tap on the website
https://www.pcspecialist.dk/gemte-konfigurationer/intel-z790-white/ZspTFm3Ywc/
Thank you in advance for your time
Hello
